Ok, what would someone recommend as best settings on a 40D, to get some good shots of a rising full moon, over a salt waterway and marsh?
trailguy Senior Member More info | Apr 09, 2009 18:05 | #1 Ok, what would someone recommend as best settings on a 40D, to get some good shots of a rising full moon, over a salt waterway and marsh?
kingdaddy Senior Member 396 posts Likes: 1 Joined Feb 2009 Location: Fort Worth More info | Apr 09, 2009 18:50 | #2 I always use ISO 100, Spot Metering, Live Mode with Mirror Lockup and a remote trigger. 6D | 7D | XSI | EF-S 10-22 | EF 50 1.4 | EF 24-105L | 100-400L │ EF-100mm Macro| MT-24EX │580 EXII | Black Rapid RS-5 | lots of Think Tank.
Apr 10, 2009 06:31 | #3 trailguy wrote in post #7700307 Ok, what would someone recommend as best settings on a 40D, to get some good shots of a rising full moon, over a salt waterway and marsh? Thanks Unless you use a long lens then the Moon is going to look very small. If you want a big, fat, Moon then you're going to need something like 3-400 mm. Frank Hollis - Retired mass spectroscopist
20droger Cream of the Crop 14,685 posts Likes: 27 Joined Dec 2006 More info | Most people drastically overexpose the moon, because they are shooting at night. Remember the full moon is in direct sunlight, even if it is dark outside at the time.
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Apr 10, 2009 12:46 | #5 kingdaddy wrote in post #7700547 I always use ISO 100, Spot Metering, Live Mode with Mirror Lockup and a remote trigger. Manual focus only and Manual Mode at F-8 to F-9 and then I just adjust the shutter speed until I can see the details in the moon in the Live View Window. It will show on the metering that it is well under exposed but don’t worry. Also Shoot in RAW. Just FYI, as soon as you go into Live View the metering changes to Evaluative. That is why it shows underexposure. Elie / אלי
PhotosGuy Cream of the Crop, R.I.P. More info | Apr 10, 2009 14:24 | #6 Moon shot with 350D & standard kit FrankC - 20D, RAW, Manual everything...
anorphirith Senior Member 356 posts Joined Jul 2008 Location: San Francisco, CA More info | Apr 12, 2009 13:48 | #7 f/10 1/60 - 1/100 1DsII 50mm f/1.4, 28-75mm f/2.8, 135mm f/2L
| Latest registered member is Niagara Wedding Photographer 1251 guests, 148 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
