Semiconductor design is certainly not in my reach, so I rather turn to a more reliable source (even though I discredited it just before, though not for being incorrect, but for being worthlessly superficial). Following paragraphs are from the White Paper, Chapter V, WHY CMOS?:
CANON'S FULL-FRAME SENSORS: THE FINEST TOOLS FOR DIGITAL PHOTOGRAPHY
Transferring voltage requires almost no power compared to transferring a charge, which must move mass. So even with a larger CMOS sensor, power consumption does not change as long as the number of channels is not increased. CCDs, on the other hand, transfer output charges ”as is,” consuming power for the horizontal reading. The bigger CCDs are, the more power they consume. Making them faster also requires more power. A Canon in-house comparison of CCD and CMOS power consumption found that with the very small sensor in point-and-shoot digital cameras, the CCD consumes 50% more power than CMOS. In the case of an APS-C size sensor, used in DSLR cameras such as the EOS Digital Rebel XT, EOS 20D and 30D, the CCD consumes more than twice as much power. With full-frame 35mm sensors, CCDs consume about three times more power as a baseline.
Because CMOS sensors have a converter at each photodiode to transform the charge to voltage, each row of photodiodes can be read separately, and multiple channels of sensor data can be read out simultaneously at high speed.
Now, listen:
CMOS sensors generally have the disadvantage of generating more electrical noise than CCDs, which can result in poor image quality. There are unavoidable fluctuations in the performance of the millions of photodiodes and amplifiers incorporated into [SIZE=2][FONT=MetaNormalLF-Roman]
a CMOS sensor, and the tiny differences in performance result in noise in the output image. To overcome this problem, Canon developed on-chip technology to record the noise of each pixel before exposure, and automatically subtract such noise from the image when it is created. The incorporation of noise reduction enables the reading of a noise-free signal. This on-chip circuitry can be added only to CMOS sensors, not CCDs, because of the differences in the way the two are manufactured.
