Thread started 10 Apr 2009 (Friday) 22:12
Dust looking through view finder
tcc
Apr 10, 2009 22:12 |  #1
Hello All,
Need a little help here. When I look through my view finder I see what I think is dust between my left most AF point and the one just to it's right (holding camera in landscape/normal position).
I fist thought it was on my lens but when I remove it and look through, it's still there.
Then I thought it might be the sensor, so I "rocket blew it". Still there.
What can it be and am I cleaning it in the right location?
TIA
Canon 7D w/grip & RRS L-plate | 100 f2.8 Macro | 10-22 f3.5-4.5 | 70-200L f2.8 IS | 24-70L f2.8 |
100-400L f4.5-5.6 | 28-105 f3.5-4.5 | 50 f1.8 | ZE 50 f1.4 | 055xProB | Acratech GV2 | flickr (external link)
agc1019
Apr 10, 2009 22:19 |  #2
It's probably dust on the focus screen. To find it, take the lens off and look up towards the viewfinder.
Wilt
Apr 10, 2009 22:44 |  #3
Agreed. Since you have an XTi, which is not designed for easy removal of the screen, leave it alone, it does not harm the photo being taken, it only irritates you.
twalker294
Joined Jan 2002
Apr 11, 2009 00:10 |  #4
It's either on the focus screen or the mirror. Get a rocket blower (do NOT used canned air,) and blow it out a few times and see if that gets rid of it.
Todd Walker
http://twalker294.post​erous.com/ (external link)http://www.twphotograp​hy.net (external link)
Canon 40D, 10D, G9, SX20IS, and SD500
Wilt
Apr 11, 2009 00:23 |  #5
twalker294 wrote in post #7707993 (external link)
Cannot be on the mirror, as that is totally out of focus!
tcc
Apr 11, 2009 16:39 |  #6
Thanks for the suggestions. I used the blower and it removed the one offending "hair" but it seems like it put some other debris on there. I tried again and it doesn't want to budge. Is the focusing screen very delicate? Can I use a dry swab (the ones you use to clean the sensor) and gently wipe across the screen?
Wilt
Apr 11, 2009 16:59 |  #7
The focusing screen is VERY delicate, you can mar the surface texture quite easily.
Ianfp
Apr 11, 2009 18:28 |  #8
I used a wet swab on mine with Eclipse and wiped it very gently in one direction. It worked really well for me.
Ian
Nikon D850, 85mm f/1.4G
5D2
EF17-40 f/4.0 L, EF135 f/2.0L EF200 f/2.8L
EF24-105L, EF100 f/2.8L Macro. EOS-M, 22mm f/2
Hasselblad 500C/M, Planar 80mm f/2.8
2,402 views & 0 likes for this thread, 5 members have posted to it.
1747 guests, 171 members online
