islandxguy wrote in post #7711818
Is there any easier way to explain whats on your sig, because I've been reading it over and over and keep in mind I'm not a hardcore PS user.
Take it one step at a time. Use sRGB for now.
I believe my monitor IS calibrated because I see all the 15 different colors on the bar and they do NOT blend together...
If you state it like that, I am fairly sure that your screen is not calibrated
So whats next? The solution to this is in your sig but it does not seem very clear to me at all
Calibrate the monitor.
Use sRGB for anything that goes on the web.
Use sRGB anyhow, until you understand color management.
The only reason to use AdobeRGB would be if you print at home (say you have an Epson R2880 or Canon iP9000)
Also--would going to Save for web and devices option, be a much easier solution to retain the same color I see? Because I've seen my pictures on other monitors beside mine and they are as they are on my monitor when I do that.
Start off by converting the file to sRGB before saving.
Save for web can do that for you, starting in PSCS3 I believe. In PSCS2 and older, you need to do that manually.
Here's a PSCS4 "Save for web" screenshot.
The original is an AdobeRGB document.
You can change the preview
of both tabs seperately by choosing another setting in the dropbox that the arrow is pointing. These are your options:
From top to bottom:
Monitor Color: Image in a non color managed application on
your screen.
Macintosh: Image as it might be seen in a non color managed application by someone using ancient Mac gamma 1.8. Useless IMO.
Windows: Image as it might be seen in a non color managed application by someone using an "sRGB" monitor. An sRGB image should look identical to the last option:
Use Document Profile: As seen in a color managed application.
All the circled tickboxes I circled in the "Save for Web" screenshot should be ticked.
