Thread started 11 Apr 2009 (Saturday) 06:59
Question for 500mm f/4 users....
davebreal
Apr 11, 2009 06:59 |  #1
Do you guys find it necessary to keep the 1.4 teleconverter off to get flights shots of small birds?
I'm having a hard time to get my 40D to pickup moving small birds in the viewfinder as is (using tc). Recently tried to get flight shots of Tree Swallows and also a bat and even pre-focusing wasn't helping too much.
Thanks.
Dave
flickr  (external link)Twitter  (external link)Wordpress Blog (external link) YouTube (external link)
My Gear--> Facebook (external link)
gymell
Apr 11, 2009 07:10 |  #2
It's very likely you'll want to leave the TC off because you'll need that extra boost in AF speed. Plus the field of view will be larger without it, making it easier to find your subject. I've tried tree swallows with the 500 with no luck at all. I'm planning to try again here this spring but using the 400 f/5.6 instead. It's easier to hand hold, very fast AF and a wider field of view.
This is the smallest BIF I've gotten with the 500, and I definitely had the TC off for this one!
IMAGE: http://www.pbase.com/gymell/image/108568472/original.jpg
-Liz
My online gallery (external link) and Live Streaming Feeder Cam (external link)
Help native birds - discourage house sparrows! (external link)
Minnesota Master Naturalist (external link) - "Explore, Teach, Conserve"
davebreal
Apr 11, 2009 07:12 |  #3
gymell wrote in post #7708949 (external link)
Thanks Liz, I'm glad it's not just me!
Dave
gymell
Apr 11, 2009 07:20 |  #4
When I was on Jim Neiger's Flight School workshop a few months ago (which is where I got that pileated woodpecker) we tried tree swallows. That was an exercise in frustration. However Jim says it's possible, so with enough practice I suppose it is. I know I good spot here near my house where I can stand out on a boat dock and tree swallows swarm all around. I think it will be a great opportunity to try it with the 400/5.6 - I'm not going to bother with the 500 again on them!
-Liz
davebreal
Apr 11, 2009 07:23 |  #5
gymell wrote in post #7708969 (external link)
Do you find the AF faster on the 400/5.6 or is just the portability and field of view that makes flight shots easier?
I'm also wondering if the AF on a more powerful full frame camera would make a difference (as compared to my 40D). Right now I completely agree with the "exercise in frustration".
Dave
andrewhuxman
Apr 11, 2009 07:51 |  #6
I have tried these birds also with the 500....... almost impossible............​. they are just too fast and too small to track with or without the 1.4. I would give praise to someone that can accomplish this task.
A little L goes a long way.
artyman
Sleepless in Hampshire
Gallery: 17 photos
Apr 11, 2009 11:10 |  #7
Is this just using the centre focus point? I have more success using manual as I find it impossible to keep the bird in the centre point, I guess it would be OK if they were filling the frame, finding them is the first problem :)
Ken
gymell
Apr 11, 2009 12:05 |  #8
davebreal wrote in post #7708979 (external link)
People say that the 400/5.6 is faster, but I don't know if the difference is enough to really be noticeable. Of course if you have IS turned on the 500, then you'd notice the difference. But at such high shutter speeds you wouldn't really need it. The Mark III definitely has faster AF, since it's made for action it's ideal for BIF.
artyman wrote in post #7709852 (external link)
I only use the center focus point for any BIF. Just works best for me. Never tried focusing manually on BIF!
-Liz
davebreal
Apr 11, 2009 12:36 |  #9
I think it's safe to say that 99.9% of experienced wildlife photographers use Autofocus when it's available, and shoot with center point focus when pursuing a solitary animal.
That's simply how it's done.
Dave
davebreal
Apr 11, 2009 12:37 |  #10
gymell wrote in post #7710076 (external link)
Is the AF much quicker with IS turned off? I hadn't tried that approach lately.
Dave
davebreal
Apr 13, 2009 10:48 |  #11
well i did finally get one!
http://drbphoto.smugmu​g.com …856_hfYrx#51110​7276_SNUoh (external link)
even w/o the 1.4tc on the 500mm f4, this was still a very lucky shot. i was prefocusing on the water and it took me quite a whie to track a bird at all AND get the autofocus to pick up the little bugger at all.
Dave
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Apr 13, 2009 14:36 |  #12
Why only the center point? If a bird is flying from right to left, isn't it better to use a point just off center to the right? And vice versa for a bird flying from left to right. This way you leave a little more sky in front of the bird. It allows for "implied motion". I feel composition is better if I give more sky/background in front of the bird than behind it.
gymell
Apr 13, 2009 15:03 |  #13
Tom Reichner wrote in post #7722047 (external link)
Because usually there isn't enough time to be switching back and forth between different focus points, and I'm rarely so close to a flying bird that there isn't space to crop as needed for composition.
-Liz
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Apr 13, 2009 15:09 |  #14
gymell wrote in post #7722206 (external link)
Liz,
Often times I chop off part of the bird because I was just too close . . . a "great shot" is ruined.
But if I take the 2x off, then the next opportunity will be at a distance, and the image will be no good because the bird didn't fill the frame.
BIF are truly a difficult challenge.
gymell
Apr 13, 2009 15:51 |  #15
True, I've chopped off parts of the bird too, many times trying to get those close flight shots. However if I've got it in the center of the frame, then I have a better chance.
IMAGE: http://www.pbase.com/gymell/image/110577607/original.jpg
-Liz
4,263 views & 0 likes for this thread, 11 members have posted to it.
1096 guests, 119 members online
