Thread started 11 Apr 2009 (Saturday) 15:22
Sensor mark
Borderfox
Apr 11, 2009 15:22 |  #1
A friend sent me two pictures from work today with a sensor mark on a lot of the shots. In the first shot it is to the right of the riders head and is fairly easy to spot in the second shot. Looks a funny one and I have never seen one like it. Any ideas if it is anything more serious? Canon 1dmk3 and happens on all lenses.
From looking at it myself it looks like sensor dust
Click Here and Join the POTN flickr Group Today! (external link)
2004ep3hatch
Apr 11, 2009 15:29 |  #2
it looks like dust to me. have you tried blowing it out?
Canon EOSR, RF24-70 F2.8L IS, RF70-200 F2.8L IS,Sigma 150-600MM-C F5.6-6.3
Jman13
Apr 11, 2009 15:35 |  #3
It looks like a spot of grease. I had a spot like that on my 1DsII sensor, and at first, I tried to blow it away, then brush it off with the SensorKlean from lenspen...which promptly smeared it all over the sensor (thought I scratched it!) Two passes with Eclipse E2 and a sensor swab and it was completely gone, though. :) No damage, clean as a whistle.
Jordan Steele - http://www.jsteelephot​os.com (external link) | https://www.admiringli​ght.com (external link)
Canon EOS R5 | R6 | TTArtisan 11mm Fisheye | Sigma 14-24mm f/2.8 | RF 24-105mm f/4L IS | Tamron 35mm f/1.4 | RF 35mm f/1.8 | RF 50mm f/1.8 | RF 85mm f/2 | RF 70-200mm f/2.8L IS | Sigma 135mm f/1.8
alexanderGARDNER
Apr 11, 2009 15:40 |  #4
Try a blower and then go out and buy an Artic Butterfly.
Sweet bit of kit!
ALEXANDER GARDNER
PHOTOGRAPHER - MELBOURNE, AUSTRALIA
alexanderGARDNER Blog! (external link)
alexanderGARDNER Photography FB Fanpage (external link)
tiha
Apr 11, 2009 15:41 as a reply to  @ 2004ep3hatch's post |  #5
It looks like big cluster of stuck/hot pixels to me. IMO that sensor needs replacing which is quite expensive repair if camera is out of warranty. :(
EOS 5D, EOS 30D, EOS 3, PowerShot G6
EF 50mm f/1.4 USM, EF 85mm f/1.8 USM, EF 100mm f/2.8 Macro USM, TS-E 90mm f/2.8, EF 15mm f/2.8 Fisheye, EF 70-200mm f/2.8L IS USM
Speedlite 580EX, Speedlite 430EX, Macro Ring Lite MR-14EX, Transmitter ST-E2
PBase: http://www.pbase.com/v​_tihomir (external link)
SPK64
Apr 11, 2009 15:56 as a reply to  @ tiha's post |  #6
Looks like dust to me. Or as others mentioned lubricant with dust.
I had the exact same thing happen to me while on vacation and stopped down the lens. Never noticed it before since most all shots were wide open.
Copperhill method is what I used.
It did take several passes to get it removed.
Before Cleaning
IMAGE: http://www.smugmug.com/photos/510259976_c5K3L-M.jpg
After
IMAGE: http://www.smugmug.com/photos/506699827_LueHU-M.jpg
Canon 1dMKiii, 20d
Canon EF 70-200mm f/2.8 L IS
Canon EF 300mm f/2.8 L IS Canon 16-35mm f/2.8 L
Canon TC 1.4x Canon EF 16-35mm f/2.8, Tamron XR 28-75mm f/2.8, Canon 580ex
3 Einstiens, 2 64" PLMs, cybersyncs
John_T
Gallery: 127 photos
Joined Jun 2003
Apr 11, 2009 16:02 |  #7
Sometimes lubricants from the camera get thrown on the sensor when the mirror flaps up and down or too heavy blowing with a bulb blower, in which case don't use a sensor brush on it as it will smear around on the sensor and contaminate the brush too. You will probably need to wet clean with Eclipse or Visible Dust Smear Away. There is also a possibility that is spit, if somebody was looking in there in cleaning mode trying to orally puff dust off or while talking. :D
There are also some big fibers on the sensor which should blow away.
Canon : EOS R : 5DIV : 5DS R : 5DIII : 7DII : 40 2.8 : 50 1.4 : 35L : 85L : 100L IS Macro : 135L : 16-35L II : RF-24-105L IS : 70-200L II : 100-400L IS II : 1.4x & 2x TC III : 600EX-RT : 580EX : 430EX : G1XII : Markins Q10 & Q3T : Jobu Gimbal : Manfrotto Underware : etc...
alexanderGARDNER
Apr 11, 2009 16:09 |  #8
As what's been said. If it's grease don't brush it out with the Butterfly.
Grab a flashlight (I've found LED works best) and see if it helps light up the dust or grease marks. You should have a better indication of how to attack it once you've sighted the foreign material.
If it's grease, use a Copperhill kit. If it's dry then blow it out first before trying the Butterfly.
ALEXANDER GARDNER
yvonchap
Apr 11, 2009 16:37 as a reply to  @ alexanderGARDNER's post |  #9
And do not forget what you see on he picture is reverse on the sensor, so what is up on the picture is down on the sensor.
Nicholas ­ R.
Joined Jan 2005
Apr 11, 2009 16:51 |  #10
It's definitely an oil mark. As previously stated, the sensor will have to be wet-cleaned before using a brush or pen.
Best,
Nicholas
www.copperhilimages.co​m/index.php?pr=galleri​es (external link)
Borderfox
Apr 11, 2009 17:00 as a reply to  @ Nicholas R.'s post |  #11
Thanks everybody, I will pass on the info. much appreciated :)
Rayk
Gallery: 271 photos
Apr 11, 2009 17:09 as a reply to  @ Borderfox's post |  #12
Yes, their is dust that is easy to clear, but their is more!!!!!!!!!!
Regards Ray
LRPS - Licentiateship of The Royal Photographic Society- CPAGB - HON CPE - ACA - Adobe Certified Associate
www.rakphotographic.co​m (external link)
Follow me on Facebook (external link)
hawkeye60
Apr 11, 2009 17:11 |  #13
Dust aside, good picture.
It's a lens not a lense!
The truest test of character is what you do when you think no one is looking.
2,987 views & 0 likes for this thread, 11 members have posted to it.
Sensor mark
894 guests, 133 members online
