Probably a silly question but why use stobes for studio work? I would have thought that constant lighting (spots, halogen etc) would be cheaper and you don't have to worry about sync or triggers or flash exposure etc.
Vendee Senior Member 466 posts Likes: 436 Joined May 2007 More info | Apr 12, 2009 18:18 | #1 Probably a silly question but why use stobes for studio work? I would have thought that constant lighting (spots, halogen etc) would be cheaper and you don't have to worry about sync or triggers or flash exposure etc. | EOS 6D| EOS 3 |EF 24-105mm f/4L|EF 70-200mm f/4L IS |EF 40mm f/2.8 STM | EF 50 f/1.8 II | Sigma 35mm f/1.4 Art | Pentax MX |Pentax ME Super|Pentax K1000|Kiev 4A|Yashica Electra 35 GTN|Yashica 24|Ricoh GR III
RichNY Goldmember 1,817 posts Likes: 3 Joined Sep 2006 More info | Apr 12, 2009 19:17 | #2 They generate a lot of heat. Nikon D3, D300, 10.5 Fisheye, 35 f/1.4, 50 f/1.4, 85 f/1.4, Zeiss 100 f/2, 105 f/2.5, 200 f/4 Micro, 200 f/2, 300 f/2.8, 14-24, 24-70, 70-200, SB-800x4, SB-900, SU-800, (3) Sunpak 120J (2) Profoto Acute 2400s,Chimera softboxes, (4)PW Multimax, (6) C-stands, (3) Bogen Superbooms, Autopoles
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Apr 12, 2009 19:20 | #3 Typical studio strobes provide much more light for an exposure than so-called "hot" lights. Skip Douglas
gryphonslair99 Senior Member 491 posts Joined Aug 2006 Location: Wichita, Kansas More info | Apr 12, 2009 19:37 | #4 Vendee wrote in post #7716757 Probably a silly question but why use stobes for studio work? I would have thought that constant lighting (spots, halogen etc) would be cheaper and you don't have to worry about sync or triggers or flash exposure etc. Sweaty models with sticky clothes and runny makeup are not in fashion at this particular point in time. You don't take a photograph. You ask, quietly, to borrow it.
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | They do have some very nice cool continuous lights but they don't produce a heck of a lot of light. This means higher ISO's, longer shutter speeds and wider apertures than desired. If you were doing only sitting portraits of adults you could make it work and produce beautiful images but anything outside of that would just give you problems and remove a lot of the flexibility you have with strobes. Robert
sfaust Goldmember 2,306 posts Likes: 10 Joined Nov 2006 More info | Apr 12, 2009 21:01 | #6 When shooting products in the studio, or even larger sets, its not uncommon to want to shoot at very small apertures. Even as deep as f32, f45, f64, especially when shooting large format. As mentioned, it comes down to power, and color consistency. Hot lights generally tend to drift some as they age. Strobes are more consistent. And trying to shoot at f32 with hot lights takes a tremendous amount of power, and the heat that comes with it. Stephen
Lithian Member 139 posts Joined Jan 2009 More info | Apr 12, 2009 22:17 | #7 I recently came across a company who made lights for tv and film. It seemed like a fairly normal light was in the 3-6kw range and they made ones up to 24kw. I'd imagine they would work quite well for still work as well
Thanks to everyone for the explanations | EOS 6D| EOS 3 |EF 24-105mm f/4L|EF 70-200mm f/4L IS |EF 40mm f/2.8 STM | EF 50 f/1.8 II | Sigma 35mm f/1.4 Art | Pentax MX |Pentax ME Super|Pentax K1000|Kiev 4A|Yashica Electra 35 GTN|Yashica 24|Ricoh GR III
Bumgardnern Senior Member 977 posts Joined Dec 2007 Location: Nashvegas More info | Apr 13, 2009 20:53 | #9 Strobes are used much more often for a variety of reasons. One of the main reasons is that they are not hot. You do not get hot sweaty models that are squinting their eyes when you use strobes. Also strobes consume way less power. With hot lights they are on constantly and they produce heat which you then have to crank the AC. Hot lights also tend to be heavier and more dangerous than strobes. A big 24k hot light is heavy. The grip gear normally associated with hot lights is also much heavier and harder to move.
| Latest registered member is semonsters 1454 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
