Thread started 13 Apr 2009 (Monday) 19:00
Maha C9000 /powerex/ Imedion / Eneloop charger.
Azzure_7
Apr 13, 2009 19:00 |  #1
Quick Question.
Tried to search with no avail.
I charged my powerex.
It's done after 45 min showing 1.45 V, showing more or less 866mah on all 4 batteries. This is one set of batteries.
Question= shouldn't the mah be higher than that?
This means I need to give a cycle. right?
On another set, It shows more or less 1200 mah on 3 of the batteries and 600ish mah on 1 battery.
This means I need to refresh and analyze?
Correct.
Note that I always use them by set.
So 1 set always go to one flash. I use a tape to mark my battery.
Thanks before hand.
Azzure_7
Apr 16, 2009 23:34 |  #2
Nobody knows this?
I know some of you use this charger..
SnlpeR
Apr 17, 2009 06:45 as a reply to  @ Azzure_7's post |  #3
if you choose only "charge"..
itll charge to its max and tell you how much it charged in mah
this doesnt mean thats the total
to find the total...do the refresh/analyze
it will charge, discharge, then charge fully from 0 to tell you its max mah capacity
Azzure_7
Apr 17, 2009 20:53 as a reply to  @ SnlpeR's post |  #4
Akh I see...
Thanks Sniper.
1,734 views & 0 likes for this thread
Latest registered member is aggrey12
1232 guests, 246 members online
