Thread started 15 Apr 2009 (Wednesday) 04:19
Before and After #177
MJA
Apr 15, 2009 04:19 |  #1
This game is to help those of us who are trying to learn new tricks when it comes to editing.
Here's the breakdown of the game. I will post a picture that I choose, resized to exactly 1024 pixels maximum on the long side. Outside of being resized it has to be unedited...meaning no adjustments to any levels, it has to look like it did as it came out of the camera.
The game will last 72hrs and whoever can produce the best edited image (as judged by me) will be picked and it'll be their turn to post their unedited picture for all of us to take a crack at.
If you happen to be the winner of the game please start the next one with the title of the game and the following number. For example…the next game should read "Before & After #178".
This is all about having fun so have at it!!!
This round will end Saturday April 18th at 05:30AM EST
Here is an early era house I saw at Fort Griswold in Groton, CT.
Mike
G10, 40D, 1D3
Lore
Damn I failed the goat
Apr 15, 2009 14:08 |  #2
LR2 - Crop, B&W, Heavy Contrast, +100 Recovery, +73 Fill Light, +10 Blacks, +21 Brightness, +100 Clarity, +Vibrance-Saturation, Curves, Hue/Saturation, NR, vingette - CS2, paintbrush, lowered flow & opacity played around, dont know what I was going for... kept going until... well until I decided I was done... LOL.
Lore
Newtophoto
Apr 15, 2009 15:19 as a reply to  @ Lore's post |  #3
Slight angle adjustment in Lightroom. Adjusted contrast +31, Recovery 23, Blacks 2, Brightness +10, Vibrance +25. In Photoshop: added grass to yellow spots using clone stamp and/or healing brush set to proximity match. Added clouds by selecting sky with magic wand(click contiguous/set tolerance to 22), creating a new layer from selection, chose filter/render/clouds, set blend mode to screen. Then add a layer mask by choosing layer/layer mask/reveal all. Then used a black brush to paint over areas where I didn't want clouds. Then set layer's opacity to 31% or so.
-Rick
Rebel Xsi EF-S 18-55is, EF-S 55-250is, EF 50 1.8II
hawkeye60
Apr 15, 2009 15:29 |  #4
Since I changed the color on the last one I thought I'd continue with the theme.
Changed colors with two adjustment layer masks, one hue/saturation and the other a selective color. Also added the new sky with some clouds on a separate layer and blended with a gradient mask and low opacity erasures.
It's a lens not a lense!
The truest test of character is what you do when you think no one is looking.
masterwillems
Gallery: 39 photos
Apr 15, 2009 15:45 as a reply to  @ Newtophoto's post |  #5
Here is my intake for this one:
Alot of burning tool use,
normal brush for the cloud and the lightning,
tilting the bench in the garden,
blackening the door,
removing a part of the roof and the chimney with the rubber stamp tool,
grayscale,
brightness contrast adjustments,
Shadow highlight adjustments,
Added noise.
IMAGE: http://i160.photobucket.com/albums/t173/masterwillems/house.jpg
Jeroen | Gear: Fujifilm X100V - Canon 450D + Lensbaby - Canon G12 | flickr (external link)
Timphoto
Creme de la Curmudgeon
Gallery: 207 photos
Apr 15, 2009 18:13 |  #6
In CS4, duplicated background layer with multiply blend mode, 50% opacity. Spot healing to fix the grass. Used dodge tool to lighten the front door. Healing tool to remove the two power lines on the right side of the house. Selected roof, new layer and painted it green at 80% opacity, selected the brick chimney to a new layer and gave it a little more red tone. Selected the sky - copied a new layer and then copied a cloudy sky from another jpg at 74% fill to match better. Added Bevel & Emboss edge - innner bevel contoured smooth. Stroke at 174 pixels.
Tim
outbri
Apr 15, 2009 21:02 as a reply to  @ Timphoto's post |  #7
My first edit contest.
Upped contrast on everything, copied house out of image. Desaturated the image, pasted house back in. Had to desaturate each window also, because they all had a blue reflections. Blurred some small bright white objects out, brushed over the antenna. Made the white building on the left a bit darker, added a bit more color to the chimney. Small window to the left of the door didn't look right, so I blurred the lines around it to make it a bit more normal.
butcha27
Apr 16, 2009 00:33 |  #8
-Slight straighten.
-Created a polarizing filter effect on the sky using a black gradient over a new level and adjusting opacity.
-Slight use of clone stamp on grass.
-Selective saturation of grass and building. ( each selected seperately and adjusted on a new layer)
-Sharpened (USM 200% at 0.3)
IMAGE: http://i177.photobucket.com/albums/w207/robsheeley/banda177alter.jpg
Rob
www.robshots.com.au (external link)
http://robshots.smugmu​g.com/Cricket/466317 (external link)
Tubarao
Apr 16, 2009 09:35 |  #9
- Duplicate, desaturate, duplicate, invert, color dodge, gaussian blur to create "sketch" layer (tutorial on how: http://www.photoshopsu​pport.com …ifer/photo-to-sketch.html (external link))
- Duplicate original to create color layer.
- Blend "sketch" layer with color layer. I used the sliders on the bottom to take out the white and smooth to the black (should've just used color burn, oops).
- Chop up the color layer and alter colors individually (hue and saturation). Blur the grass and the trees.
- Cut sky to new layer. Hue to pink. Gradient overlay from black to transparent on Dissolve mode at low opacity (~40%). Merge style then tiny horizontal motion blur to give it sketch effect. Overlay entire layer again with very low opacity (~15%) gradient from blue to transparent.
- Altered colors some more on advice of a painter.
~Tubarao
http://www.korolovphot​o.com (external link)
AngryCorgi
-Bouncing Boy- a POTN peion
Location: Surrounded by bunnies, squirrels and a couple of crazy corgis in NoVA...
Apr 16, 2009 17:05 |  #10
I thought this might look decent in a dusk-type setting with some light fog in the trees where the elevation is a tad lower. I started with a mignight filter, then used a reversed-graduated-ND filter, selectively added a touch of fog, threw in a skylight filter and some gentle vignetting for mood. I think it feels sort of Sleepy-Hollow-ish. ;)
IMAGE: http://farm4.static.flickr.com/3353/3448766600_5d1915c374_o.jpg
AngryCorgi (external link) (aka Tom) ...Tools...
...Knowledge is knowing that a tomato is a fruit, Wisdom is knowing not to include it in a fruit salad...
tkbslc
Apr 16, 2009 23:39 |  #11
I decided that the house was not big enough, and I thought it would look better at night
To extend the house, I copied sections of house and overlayed them with new layers and used eraser to blend. Needed A little clone action, too.
Then I added a couple layers, one with a shadows/highlight tweak, and another a hard light overlay. Adjusted opacity and flattened. Cropped and extended canvas. Used smudge to fill the extra canvas with sky. Pasted a full moon in from one of my own pictures. Eraser to blend. brightness, contrast and levels to adjust lighting to look like after dark.
Fun edit! I think I may have gone overboard, though.
Taylor
EOS Rp | iPhone 11 Pro Max
outbri
Apr 17, 2009 00:40 |  #12
IMAGE: http://i725.photobucket.com/albums/ww260/ridatab/banda177alter2.jpg
That thing was meant to be three stories...
Going off butcha's edit. My second edit so this one doesn't count. Was fun anyway. :D
brennasg
"Late to the party!"
Apr 17, 2009 11:47 |  #13
started in lightroom 2- crop/straighten, kicked up vibrance and clarity(big time), took saturation to -24, hue shifted(green red orange magenta), saturation shifted(all), luminace shift(orange, red)
moved to CS4- cloned out the antenna, cloned in two additional windows..repaired color in bottom right window
back to lightroom- final crop, vignette.
I didnt add any grass I decided I liked it yellow and bare:)
Franklin Tn Baby Photographer (external link) | Blog! (external link) |Follow Sparkling Seal on Twitter (external link)|Facebook (external link)
Kendoway
Cropped and Creamed
Apr 17, 2009 15:11 |  #14
As always, you are all so kind to put up with my weekly nonsense. I really like to challenge myself to something new, so for some odd reason I started out with this as simple edit, and it slowly bloomed into a monster. At first I was going for a haunted house (v1.0 had gargoyles and lighting), and then it started to evolve into the Bates Motel (I have no idea why), and from there it grew into a vintage movie poster homage. I had a blast doing this!
  • Cropped
  • Straightened
  • Cropped again
  • Canvas increased
  • Much of the background removed.
  • Sky removed
  • Bench removed (clones and copies)
  • Bushes removed (clones and copies)
  • Picket fence increased (clones and copies)
  • Center 2nd story window made as the others (copy + paste)
  • 2nd story added (heavy copy and paste)
  • Windows moved up.
  • 2nd Chimney added - moved, blended, smudged
  • House trim moved, shadow added manually (center)
  • New house moved into position and pasted.
  • Levels.
  • Curves
  • Saturation (+18%)
  • Brightness + Contrast
  • Channel Mixer - monochrome + red
  • Fence burned.
  • Bates motel sign added - levels + curves, rotate, scale
  • Janet Leigh added (separate download - shower scene) - scaled - burned, opacity set 25%
  • Vintage Hitchcock movie poster (re-release of the film) downloaded, cropped, cut - paper wrinkles removed - changed saturations, removed artifacts.
  • Anthony Perkins touched up with some un-sharp mask.
  • Credits moved pasted below.
  • Audience warning re-cropped, saturated, pasted.
  • New blurb text added (poster was too shabby for a cut + paste). Outer glow.
  • Frame from a 2nd Psycho poster added as a background layer and cropped.
Elements of the 2nd Psycho release movie poster - copyright: Shamley Productions and Universal Pictures
Still of Janet Leigh - copyright: Universal Pictures
IMAGE: http://i42.tinypic.com/20hke0x.jpg
☼ Christian D.
"Ask someone who’s running out of a burning home what they’ll grab. Nine times out of 10, it’s the photo album".
- Scott Bourne
Website (external link)
| FaceBook (external link)
frenchfx
Gallery: 71 photos
Best ofs: 5
Apr 17, 2009 16:42 |  #15
crop and straightened
Converted to b\w with BW Styler and added a copper tint
Created another layer and used various brushes for the washed out effect /flattened
Opened up in LucisArt and used plad #3 at 40% w\3rd button
I still didn't like it so I used a new brush, script_brush by ladyVictoire to add the writing.
IMAGE: http://frenchfx.smugmug.com/photos/514593578_Tz9TB-L.jpg
My site Frenchfx.com | (external link)
3,781 views & 0 likes for this thread, 16 members have posted to it.
1586 guests, 138 members online
