Thread started 16 Apr 2009 (Thursday) 17:37
having a go at BW photography
scermat
Gallery: 32 photos
Apr 16, 2009 17:37 |  #1
i'm pretty new to this. any tips about improving BW conversions? some crit i recieved today was that it's better to create more contrast for BW so i had a go at "improving" on something i already had but i'd like to hear more...
Canon EOS 1DX Mk III + Canon EOS 1DX Mk II + Canon EOS 1D Mk IV + 24-105mm f4L IS + 50mm f1.8 + 100-400mm f4.5-5.6L IS + 70-200mm f2.8L IS + 500mm f4L IS
http://www.matthewscer​ri.com/wildlife (external link) - http://www.matthewscer​ri.com (external link) - https://500px.com/matt​hewscerriwildlife (external link)
cdifoto
Don't get pissy with me
Apr 16, 2009 17:42 |  #2
Looks nice and moody but I think some of the sky is blown. Can you pull those down a bit?
rraman
Joined Oct 2003
Apr 16, 2009 21:37 |  #3
Agree about blown out sky and also the details in the darker area are missing. I guess if you could post original, some of us could give it another shot.
Raman
5D Mark II | 40D | Canon 17-40mm f/4 L| Canon 50 mm f/1.8 | Canon 100mm macro f/2.8
www.theZenArt.com (external link)
aram535
Apr 16, 2009 22:50 |  #4
Also you lost all of the detail in the black and gray areas. I can't imagine all that "black" is "black". You also want to move your subject off of the center of the image.
Gear List * www.tranquilphotos.com (external link) * My Blog (external link)
scermat
Gallery: 32 photos
Apr 17, 2009 17:48 |  #5
thanks for your comments. really appreciate you taking your time to reply.
this was the "original" (it's what i brought out of ACR). initially i didn't do a lot of changes except slightly adjust the levels but i was told that it's too "grayish" and there needs to be a greater distinction between the white areas and black areas. i guess i overdone it as it is true that detail was lost in both black and white areas.
aram535
Apr 18, 2009 07:47 |  #6
Not sure what "too grayish" means, but I can see that the range is limited. Did you shoot the original in B&W? For the future I suggest capturing everything in RAW, its easy to convert it to B&W afterwards.
Yes, you did lose some of the darker details, but I actually like the range of the 2nd image than the 1st, but I like the crop on the 1st image.
tonydee
Apr 18, 2009 09:16 |  #7
The original in post #5 is much better than the edit in post #1. The original histogram is:
Clearly there aren't many tones linking the bright sky and darker ground... hence the dip in the middle. You could select the sky and use "curves" to create some overlap, very roughly...
Still, the composition isn't great... I don't like it being so central.
Cheers, Tony
5D and too much glass. Mamiya 645E.
http://www.picasaweb.c​om/anthonypon (external link) recent work
934 views & 0 likes for this thread, 5 members have posted to it.
1025 guests, 108 members online
