What's the best way to resize an image in PS i.e. to make it smaller prior to print, to keep it at it's best resolution.
1: resize in Edit - Transform - Scale
2: Image - Image size
3: Print - Scale
Locton Member 86 posts Likes: 13 Joined Nov 2008 More info | Apr 16, 2009 17:42 | #1 What's the best way to resize an image in PS i.e. to make it smaller prior to print, to keep it at it's best resolution.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Apr 16, 2009 20:15 | #2 Image -> Image size is what I use. Doing that you get to choose your sampling algorithm, though the default bicubic's good. I don't print my own though, this is what I do before I send images to the lab. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Apr 16, 2009 20:31 | #3 |
Damien if you use your crop tool you are not resizing your image, you are cutting part of your image away.
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Apr 17, 2009 06:15 | #5 |
So i tried your method damien, never used the crop tool for resizing an image before, a little strange at first but yes it does work, but i still have no answer to if one way over another is better for image quality.
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Apr 17, 2009 16:24 | #7 Locton wrote in post #7745131 What's the best way to resize an image in PS i.e. to make it smaller prior to print, to keep it at it's best resolution. 1: resize in Edit - Transform - Scale 2: Image - Image size 3: Print - Scale I'm pretty sure (1) and (3), like the Crop Tool, will use the resampling method set in PS's preferences.
| Latest registered member is semonsters 859 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
