At the net is fine, you will be probably 5-7 feet from the net. For tennis, here are some tips:
- pre-focus at certain spots
- for right-handed players, pre-focus on the left players return of serve on the forehand side, and the right players backhand side (around 5 feet from where they set up).
- for mens tennis, particularly doubles, anticipate the player rushing the net by focusing around the service line for the first volley
- get a shot of each player in ready position waiting for the serve. No action here, but this make an easy to focus tennis portrait shot
- be sure to get shots of the backswing prior to contact, contact, and then the follow-through - 3 timing shots. Same is true with the serve.
- depending on your light, shoot most of your shots when you have a good background - hopefully one or both ends of the court will have windscreens that will give you a solid background
- take some high shutter speed shots to freeze the ball, but also take some a little slower to show a little motion of the ball and racket
- one thing I like to do when looking through the veiwfinder is keep the other eye open. This helps anticipate when the ball will be entering the frame
- stay focused after the point is over to get reaction shots
- take alot of pictures - you never know which one will be the winning shot
Good Luck and have fun!!!
