The moon has always been one of my favorite subjects. Now, with the 100-400, I can actually do it some justice.
![]() | Byte size: ZERO | Content warning: NOT AN IMAGE |
Any comments or suggestions to improve are always welcome.
Kiernan Senior Member 293 posts Joined Oct 2003 Location: Fussa, Tokyo, Japan More info | Apr 15, 2005 20:25 | #1 The moon has always been one of my favorite subjects. Now, with the 100-400, I can actually do it some justice.
Any comments or suggestions to improve are always welcome. ![]() - Chazz
DanteKing "Cream of Corn" BurgerMeister 9,134 posts Joined Jan 2005 Location: San Anselmo, California More info | Apr 15, 2005 22:55 | #2 I like it. What was your exif on this shot? Dante
Thanks. I think this was the RAW I used for this one: - Chazz
cfcRebel Cream of the Crop 10,252 posts Joined Feb 2005 Location: Austin, TX More info | Wow, after looking at the exif, i realize how little I know, not even tip of the iceburg. Fee
cfcRebel wrote: Wow, after looking at the exif, i realize how little I know, not even tip of the iceburg. Please pardon my ignorance. Normally the light reflected from the moon is quite dim, but i saw you set your aperture to f8. Is that the widest when you zoomed in at 400mm? If no, why not use the widest aperture? I assume DOF doesn't come into play when using the widest f since the moon is so far away, correct? Thanks in advance. I've played with moon shots for quite a while. I've always gotten the best results at 8. Dunno why, but I do. I generally set it at f8 and take 10 pictures or so at various shutter speeds. A full moon can force 1/300 or higher at ISO 100. The moon is actually quite bright. Remember, it's basically reflecting direct sunlight. - Chazz
cfcRebel Cream of the Crop 10,252 posts Joined Feb 2005 Location: Austin, TX More info | Kiernan wrote: I've played with moon shots for quite a while. I've always gotten the best results at 8. Dunno why, but I do. I generally set it at f8 and take 10 pictures or so at various shutter speeds. A full moon can force 1/300 or higher at ISO 100. The moon is actually quite bright. Remember, it's basically reflecting direct sunlight. I see. Thanks for the clarification. I definitely need to save up a little more to get one of those. Fee
| Latest registered member is ANebinger 536 guests, 153 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
