Thread started 18 Apr 2009 (Saturday) 22:21
Trying to Shoot a Picture at Night With My PowerShot SX10 Is
H-Mac
Apr 18, 2009 22:21 |  #1
Hey guys I'm trying to take pictures at night but all my pics keep coming out dark or blurry. I am a beginner at Photography but I am trying to learn. If anyone can help me out a bit I would appreciate it. i'm going to attach some of the pics I took just now. I tried putting the camera on "NIGHT SCENE" but they come out dark. I tried it in the M mode and I tried adjusting the aperture and the shutter speed but that has me lost. Help Please:confused:
IMAGE: http://i44.tinypic.com/6pordj.jpg
IMAGE: http://i41.tinypic.com/29o0bbo.jpg
~Trying To Capture The Beautiful Moments In Life with my Canon PowerShot SX10~
julioangelortiz
Apr 18, 2009 23:54 |  #2
A tripod would be essential. Any long exposure pics would need to be mounted on a flat surface or tripod to avoid any kind of movement. Also, set the self-timer to 2 or 10 seconds (or use a remote; I don't know what the SX10 has this ability) so that any initial movement with pressing the shutter won't affect the picture. I hope that this helps.
Canon SX280 HS
Google+external link | Instagramexternal link
pelawancai
Apr 28, 2009 10:49 as a reply to  @ julioangelortiz's post |  #3
You can use Tv dial, set it to 5 - 10 seconds, ISO 200. Fix your camera on tripod. Yes, using self-timer can prevent camera shaking.
Pelawancai
neilwood32
Apr 28, 2009 11:02 |  #4
If you are trying long exposures (anything over 1/focal length) then additional support is likely to be required.
Tripod is best but a beanbag, sweater, railing have all worked for me in the past.
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
GDane123
Apr 28, 2009 16:14 |  #5
pelawancai wrote in post #7819049 (external link)
Pelawancai
I haven't thought of a use for self-timer yet, except if I ever want to jump in a group shot. So how does using that help prevent camera shake? The movement from pressing the button is what you're referring to?
All shots done with Canon SX10
http://photobucket.com​/GDane123 (external link)
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Apr 28, 2009 21:34 |  #6
That, & mirror slap, if your camera has one.
Forget "NIGHT SCENE". Shoot some tests in manual, about 2 f-stops up from wide open, which is where your lens is probably sharpest.
And, some of the best "night shots" I've seen were taken before it's totally dark while there's still some light left in the sky. You don't need much, but you need some.
Lets See Your 30 sec. exposures
pelawancai
Apr 29, 2009 08:12 |  #7
GDane123 wrote in post #7820819 (external link)
The moment you press and release shuttle button will cause camera shaking.
When self timer is being used (use the option 2 or 10 seconds or custom), once you releasing from the shutte button, your camera still have time from shaking to steady. Then the outcome of your picture will not have blur result.
Pelawancai
Bob_A
Gallery: 48 photos
Joined Jan 2005
Apr 29, 2009 08:31 |  #8
As mentioned above a tripod is essential since at any focal length most people can't take a steady hand-held shot at a shutterspeed slower than 1/30s, and if you zoomed in with this camera you may even need a minimum of something like 1/300s to avoid blur (guessing a bit, but I'm probably close). Get a good tripod (ask here for suggestions) as the sturdier the base the better your images. This is much, much more important to using timer mode to release the shutter for long exposures, but using timer mode certainly helps too.
Also, I know you used flash for both of the images posted, but it only helps illuminate anything 5-10 feet from the camera. Further than that the onboard flash doees little to nothing.
Get a tripod, make sure that you have something bright in the image for the camera to focus on, and try Manual. Follow PhotosGuy's advice and pick an f-stop that stops down a bit from wide open (use f/4 instead of f/2.8 ), leave it at ISO 100 and then just try different shutterspeeds until you get what you want.
And what you want for a result is totally up to you. For example I like the exposure for the darker image you posted (ISO200, 1/3s, f/2.8 ). You may have been going for what you got for the lighter one (ISO200, 6s, f/6.3).
Bob
drlmel
May 28, 2009 13:30 |  #9
On this same line, I am trying to use this camera to shoot sports (action) shots at night but not having much luck. Does anyone have any suggestions?
egordon99
May 28, 2009 13:53 |  #10
There are people shooting 40Ds and $1500 lenses that are "not having much luck" trying to shoot night sports. Hate to be the bearer of bad news, but I don't think there is anything you can do with your SX10. Depending on the sport, you're looking at upwards of $10K on a body/lens (something like a 1DMKIII and 400mm f/2.8)
drlmel wrote in post #8005459 (external link)
drlmel
May 28, 2009 14:08 |  #11
I am not asking for a miracle, just decent. I used to use a Sony HDR-CX12 and it did ok but grainy. I was hoping for just the same or a little better with this cannon. I have tried different settings but it just doesnt seem to be as "clear" as the Sony.
CAL ­ Imagery
May 28, 2009 14:16 |  #12
How far away and what was your EXIF?
Christian
drlmel
May 28, 2009 14:22 |  #13
nphsbuckeye wrote in post #8005712 (external link)
I can get as close as about 50 feet and what is a EXIF?
dharrisphotog
May 28, 2009 15:10 |  #14
My SX10 IS is what made me upgrade to the XSi. The camera is just horrible. Overblown highlights no matter what I did. People are better off with just a regular Canon P&S. If you're going to spend that kind of money, get an XTi or XS.
D800 | Sigma 35mm 1.4 Art | Nikkor 85mm 1.8G | Nikkor 70-200 2.8G
Gear | Facebook (external link) | Twitter (external link) | Flickr (external link) | Google+ (external link)
6,998 views & 0 likes for this thread, 11 members have posted to it.
1791 guests, 120 members online
