Thread started 19 Apr 2009 (Sunday) 18:03
DPP - Please explain the two "Sharpness" adjustments
bsmotril
Gallery: 11 photos
Joined Feb 2006
Apr 19, 2009 18:03 |  #1
Within Canon's DPP, there are two options for adjusting sharpness within the tools palette. One is on the first "RAW" tab, and I'm assuming it is the same as the in camera sharpness option inside picture styles. The other sharpness slider is on the RGB tab and paired with the hue and saturation sliders. What is the difference between the two different sharpness adjustments and how they work?
Galleries: http://www.flickr.com/​photos/smopho/ (external link) --- http://billsmotrilla.z​enfolio.com/ (external link)
USER876
Apr 19, 2009 22:00 |  #2
I view the one in the raw tab an "input sharpening." This is basically overcoming the softness that the cameras anti-alias filter creates. I only sharpen using this so that the picture looks "acceptable and clear." Usually this is between 2-5, (most of the time on 3).
The sharpening in the other tab, provides you with more control (zero to 500 increments), and I use this as "output sharpening." Apply this last, after make other color/curve adjustments,etc. You may want to apply more if you are printing, vs downsizing for web viewing,etc.
René ­ Damkot
Apr 20, 2009 06:04 |  #3
bsmotril wrote in post #7763030 (external link)
As far as I know: Nothing. Only the "numbers" are different. The effect is the same and additive.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
glockamole
Apr 20, 2009 07:34 |  #4
I assumed that the second one was there for jpegs.
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
Apr 20, 2009 07:50 |  #5
glockamole wrote in post #7766387 (external link)
According to Canon support, yes. That's why Rene's answer is correct. For jpeg shooters, it's the sharpen option. For RAW shooters (because the raw tab is enabled) the two options are redundant. I personally never sharpen in DPP. I click it down then use specialized sharpening tools such as NIK or TLR in PS. But then my workflow does not have the demands of high production shooters, either.
Website (external link) |
bsmotril
Gallery: 11 photos
Joined Feb 2006
Apr 20, 2009 11:24 |  #6
Thank you all for the explanations.
1,581 views & 0 likes for this thread, 5 members have posted to it.
886 guests, 118 members online
