I'm looking at a used 1DMKIIn tomorrow as a potential purchase. Is there anything in particular I should be looking for that was problematic with these cameras?
Thanks,
Apr 23, 2009 07:54 | #1 I'm looking at a used 1DMKIIn tomorrow as a potential purchase. Is there anything in particular I should be looking for that was problematic with these cameras? Gear List
sonnyc Cream of the Crop 5,175 posts Likes: 36 Joined Jun 2005 Location: san jose More info | Apr 23, 2009 13:09 | #2 |
LukeCern Senior Member 926 posts Joined Jan 2005 Location: Torquay, Devon, UK More info | Apr 23, 2009 13:35 | #3 bsmotril wrote in post #7787395 I'm looking at a used 1DMKIIn tomorrow as a potential purchase. Is there anything in particular I should be looking for that was problematic with these cameras? Thanks, There doesn't appear to be any inherent bugs in this camera. I own one. I would suggest that you check the previous ownership of the body. Was it used by a professional sports photographer? Bear in mind that sports photographers using the 1DMKIIN will always take bursts of images. That means that shutter count will rise at three to six times the rate of a "stills" photographer. When you get one, you'll do the same! A general 30k shutter usage on a 5 D is likely to result in more like 90k on 1 DMKIIN. The shutter count CAN be read by special software, but don't accept an estimate. If the body has lots of obvious wear, be very cautious. Mine certainly has, and I regret not examining it before purchase. I also found that a professional clean of the sensor a short while after I made the purchase improved the camera enormously. Best $50 I spent!. You never know what cleaning technique the previous owner used and althought dust may not be the problem, a residual film of old cleaning fluid can dull your images. Other POTN'ers didn't agree with me paying someone to clean the sensor, but I noticed the difference immediately afterwards. ______________
drhee39 Member 36 posts Joined May 2008 Location: LA CA More info | Just my experience--I'd suggest trying the cam with your fast primes wide open to see if it's grossly in focus. My 1D2N was great until I started getting into the 35 1.4, and found it consistently front focused. Unfortunately, it couldn't be calibrated after multiple attempts. Otherwise, I would agree, it's hard to go wrong with a 1D2N, especially given the prices out there.
sf1 Goldmember 2,021 posts Joined Mar 2007 Location: Calgary, Canada More info | Apr 23, 2009 16:35 | #5 Its a great camera. Look for good conditioning and ask about shutter count, although the shutter can go at 1 click or 200,000 clicks. Canon 5DII, Canon 1D Mark II N
M3Rocket Senior Member 580 posts Joined Jul 2005 More info | Apr 23, 2009 19:49 | #6 Make sure you check for possible signs of impending shutter failure. These manifests itself as light or dark bands in photos taken at high shutter speeds.
Apr 23, 2009 21:20 | #7 Thanks for the tips. Gear List
| Latest registered member is semonsters 886 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
