I have a 18-55 kit lens. What advantage if any would a nifty-fifty have over the 18-55?
tawcat Senior Member 433 posts Joined Mar 2009 Location: Cammack Village, Arkansas More info | Apr 23, 2009 13:41 | #1 I have a 18-55 kit lens. What advantage if any would a nifty-fifty have over the 18-55? Yes, a picture really is worth a thousand words!
Akkis Junior Member 28 posts Joined Mar 2009 More info | Apr 23, 2009 13:41 | #2 Nifty Fifty is a faster lens and is a prime lens. Canon 5D gripped | Canon 10D gripped | Tamron 28-75 2.8 | Canon 70-200 4L | Canon 50mm 1.8 | Canon 28-105 MK II | Elan 7
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | f/1.8 is MUCH faster than f/5.6.
estisdal Member 208 posts Joined May 2007 Location: Columbia, SC More info | Apr 23, 2009 13:58 | #4 egordon99 wrote in post #7789464 f/1.8 is MUCH faster than f/5.6. This pretty much sums it up. F/1.8 is approximately 3 1/3rd stops faster than F/5.6. To put it in real world terms, a scene captured at F/5.6 with a shutter speed of 1/25s could be taken at F/1.8 w/ 1/250s. That's the difference between a blurry vs. crisp basketball player!
Subimatt Senior Member 522 posts Likes: 2 Joined Feb 2008 Location: Albany, NY More info | Apr 23, 2009 14:13 | #5 |
JackProton Goldmember 2,348 posts Joined Feb 2007 More info | Or, to put it another way, the 50mm f1.8 passes on over 8 time more light than than the kit lens can in the same situation. That gives it a great practical advantage in low light when you need a fast shutter speed. The wide aperture also allows you to blur out the background so you can seperate your subject from the background.
NYC2BGI Senior Member 846 posts Joined Feb 2005 Location: Brooklyn, NY USA More info | Apr 23, 2009 14:19 | #7 I keep telling my sister to use her 50mm over that same slow kit lens but she does not understand. She feels limited by the set focal lenth of the 50mm prime especially when taking indoor pictures of people who are posing. I guess people have to use whatever they are comfortable in using. Canon 5D3, 5D2, 40D
jblaschke Goldmember More info | The Nifty, in addition to being faster, is also sharper. Stopped down to f/2.8, the 50 will give you crisp detail the kit lens can't touch. That's generally the advantage of prime lenses--since they're not changing focal length, they excel at resolving detail. It's a tradeoff of convenience vs. image quality. The early zooms were so optically bad it established a bias that's persisted to this day in some corners. Generally speaking, a quality prime will always be better than a zoom at a particular focal length, but modern zoom lenses have gotten really good. Canon 7D | Canon 50D IR modified | Canon EF 70-200mm 2.8 IS L | Canon FD 500mm 8.0 Reflex | Canon EF 85mm 1.8 | Canon EF 50mm 1.8 mk I | Canon EF-S 10-22mm | Tamron 28-75mm f/2.8 | Meade 645 (762mm f/5)
mjmackinnon Senior Member 808 posts Likes: 2 Joined Jan 2009 Location: Ontario, Canada More info | You also need to seriously look into what sort of shots that you are doing. Go back and see if you use 50mm all that much. My Flickr
tawcat THREAD STARTER Senior Member 433 posts Joined Mar 2009 Location: Cammack Village, Arkansas More info | Apr 23, 2009 14:37 | #10 Thanks guys. I guess the part I missing was the "prime" part. Basically just shooting everyday vacation/nature type shots. Yes, a picture really is worth a thousand words!
| Latest registered member is Niagara Wedding Photographer 1332 guests, 109 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
