Thread started 25 Apr 2009 (Saturday) 23:30
What did I do wrong?
GMHY
Apr 25, 2009 23:30 |  #1
All three pictures were taken within a few minutes from the same point, with the same equipment:
Rebel XSi
Canon 70-200 2.8 IS + TC Kenko 1.4 300 pro (EXIF 270 mm for the Goldfinch, 280 mm for the Woodpecker) - AF on - IS on
Manual exposure, f/4 , 1/400 (Goldfinch) - 1/500 (Woodpecker)
ISO 400
Canon Speedlite 580 EX II, -2/3 stop, H synchro (Goldfinch only, no flash for the Woody).
For the Goldfinch, I was laying on my deck floor, the foot of the collar's lens propped on the lower bar of the deck's railing, lens pointing through the railing. I took a small series of the bird, all of them as bad as the pics shown here.
At the same time I saw the Woodpecker arrive close to another feeder, 90 degrees from the Goldfinch position. I shot him several time, sitting on the deck, elbows propped on my knees - the whole series shows more or less the same quality as this one, sharpness wise. The Woody was closer than the Goldfinch (I would say 15 feet vs 20 feet, give or take).
The pics are 100% crop of the JPEG, straight out of the camera (cropped and saved as JPEG high quality (10) with PSE6 - no other edition). Sharpness is set at +2 in camera, plus a little bump in saturation, nothing else.
What I do not understand is the obvious difference in sharpness between the the series of Goldfinch and the series of Woodpecker.
Can the shutter speed difference (1/400 vs 1/500) be enough to cause such a difference? Even with the IS on?
The Goldfinch is a nervous little bird, usually moving all the time, and fast - could it be that 1/400 is not enough to freeze this little guy?
I should say that the lens is fresh from Canon, with a new front element and second lens assembly, calibration redone, factory set up. No filter mounted.
Any explanation welcome, and thanked in advance.
Gerard
Goldfinch 1:
Goldfinch 2:
Woodpecker:
Gerard
artyman
Sleepless in Hampshire
Gallery: 17 photos
Apr 26, 2009 03:08 |  #2
Did you give the IS time to spin up, they just look out of focus to me. How does the lens perform without the 1.4
Ken
GMHY
Apr 26, 2009 06:41 |  #3
There is a possibility I did not give enough time to the IS? Sometimes you're in a hurry with these moving little things - but normally I do.
The lens is OK after coming back from the Canon spa - better than it has ever been.
Gerard
Gerard
gasrocks
Apr 26, 2009 09:38 |  #4
Do not expect to get any good results using a TC unless you stop the lens down 2-3 f/stops from wide open (you took these wide open.) Nothing looks to be in focus. Turn off the sharpening and color boost in camera - do all that in PP if needed. I do not understand why you are using a flash. Yes, give IS time to engage and lower your shutter speed if necessary.
GMHY
Apr 26, 2009 12:15 |  #5
gasrocks wrote in post #7806300 (external link)
Well, I shot wide open to gain some shutter speed while avoiding to boost the ISO too much...
And this does not explain why the Woodpecker series is far better (though no prize winning I know) than the Goldfinch series...
Sharpening and color boost: it's just for the JPEG - I always shoot JPEG + raw and use the raw files (LR2) for the good shots anyway - these were only to show two series with identical treatment for comparison.
Obviously I won't work on the raw versions of these :oops:
Thanks for the comments anyway - I'll do some tries stopped down and with more ISO.
And, I use the flash for fill in when I have a bright background - and the flash should not harm sharpness, or should it? I would not see why?
Gerard
Gerard
davebreal
Apr 26, 2009 19:34 |  #6
it would be best if you could post the unaltered originals here so we can determine exactly where and how the autofocus was hitting.
other advice - use a tripod whenever possible, expect massive deterioration from cropping, shoot and recompose several times whenever possible to avoid mishaps. for small and moving birds you will often need shutter speeds nearer to 1/1000s. stationary birds can be done between 1/100-1/200th in good conditions.
Dave
flickr  (external link)Twitter  (external link)Wordpress Blog (external link) YouTube (external link)
My Gear--> Facebook (external link)
GMHY
Apr 26, 2009 20:19 |  #7
davebreal wrote in post #7808864 (external link)
The crops are taken at the center of the pics: the AF was full center of the body of the Goldfinches - more or less at the shoulder of the Woody (trust me, no other part of the pics are in focus).
True that the Woody was stationery often during several seconds before changing position.
I shot several this afternoon without TC and stopped down (5.6 / 6.3) et they were far better, even at 800 ISO. Even shot two decent Goldfinch (not processed yet). Next, I need to try this with the TC.
Thanks to everybody for the advice. Steep learning curve I guess :)
Gerard
Gerard
davebreal
Apr 26, 2009 20:28 |  #8
GMHY wrote in post #7809130 (external link)
Gerard
What autofocus mode and autofocus points do you have set?
I'd recommend AI Servo w/ Center Point focus
Dave
GMHY
Apr 26, 2009 20:49 |  #9
davebreal wrote in post #7809191 (external link)
Always center point focus; I normally use one shot AF - I started using AI Servo this afternoon; seems to work, although I'm not sure if it's the reason for the improvement?
Gerard
gasrocks
Apr 27, 2009 08:42 |  #10
I know you wanted to see beautiful Wisconsin this summer. I teach many photography classes at U.W. including one on just wild birds. Come for a visit.
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Apr 28, 2009 19:03 |  #11
GMHY wrote in post #7809310 (external link)
The reason the finch images were blurry? One possibility is that you opened dyourself up to OOF birds by using one shot AF. If you locked in on a finch, and then he moved (even just an inch) before you clicked the shutter, then he'd be out of focus. Perhaps this happened with the finch, but not with the woodpecker.
Using AI focus mode all the time will eliminate this possibility. Just keep the active AF sensor right on the bird's eye at all times, with the shutter release button pushed halfway down - then click away whenever you think the bird's position will make a good image.
HeathNC
May 03, 2009 07:16 |  #12
Were these shot through a window? I see reflections.
Canon 30D gripped, 55-250IS, 18-55IS
GMHY
May 03, 2009 20:55 |  #13
gasrocks wrote in post #7811749 (external link)
Sorry, not possible due to family obligations - I'd love to, but I guess I will have to teach myself :-)
Gerard
GMHY
May 03, 2009 20:57 |  #14
Tom Reichner wrote in post #7821689 (external link)
Sorry for the delay, I've been travelling all past week.
This is indeed a possibility - I will practice this (AI focus) during my next session.
Thanks a lot.
Gerard
Gerard
GMHY
May 03, 2009 20:59 |  #15
HeathNC wrote in post #7848468 (external link)
Nope, no window and no reflections; some blurred twigs may look like reflections though.
Gerard
Gerard
3,299 views & 0 likes for this thread, 6 members have posted to it.
939 guests, 122 members online
