Ever since this discussion back in February, I've been meaning to run some calibration tests. This will be totally boring to most people, but I hope at least Lowner and gcogger may read it
(I'll have to break this up into several posts, because of the image limit.)
I used my trusty Eye One Display 2, and my guinea pig was a run-of-the-mill LG Flatron L1919S
TN panel monitor (coupled with run-of-the-mill onboard graphics - SiS 661FX if that means anything to anybody).
The Prep
I wanted to try various calibration targets, mainly to assess banding. Monitor banding is so feared among photographers, but I've never seen it, so I wanted to find some. I felt like Captain Ahab seeking Moby Dick.
My monitor's factory defaults are:
Brightness 100%
Contrast 70%
Red, Green and Blue (when activated) 50%
Now, I had a list of various targets and methods I wanted to try (see below), but of course I couldn't try every single possible combination. So I decided to
(a) stick to Luminance target of 100, which has always served me well.
(b) follow the EyeOne's lead on the Contrast setting each time. I have no quibble with Contrast (at least, I thought not - more about that later)
Test 1 - Targets: Native/Native/No change
Targets: Native white, Native gamma, No change luminance (let's start by seeing just how bright this baby can be)
Method: Started with factory defaults (100, 70, 50/50/50) then took Contrast up to 100 per EyeOne's instructions.
Resultant monitor settings: Contrast 73, all others unchanged.
Calibration result: 6100K, 257cd/m2 - damn that's bright!
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
Test 2 - Native/2.2/100
Method: Started with factory defaults, then adjusting Contrast and Brightness per EyeOne's instructions
Resultant monitor settings: Contrast 73, Brightness 2.
Calibration result: 6200/2.2/101
Close-up of highlight end of Gray Ramp:
Tests 3 & 4 - 6500/2.2/100
Method: Started with factory defaults, then adjusting Contrast and Brightness per EyeOne's instructions. DID NOT adjust monitor white settings in any way - I wanted this to be done all in the profile.
The difference between these two tests was that in one I chose "RGB presets" and in the other I chose "RGB Controls". In both cases, however, I didn't actually change these monitor settings, just pressed "Ok" to continue. I didn't expect much difference between these two tests, and I was right.
Resultant monitor settings: Contrast 73, Brightness 2, just like before. During the calibration, the white read as 6200, as previously.
Calibration result - Test 3 (presets): 6500/2.2/87. It hit the target using the profile, but apparently at the expense of the luminance. Check out that Gray Ramp.
Calibration result - Test 4 (controls): 6500/2.2/83. Almost identical to above.
