Thread started 26 Apr 2009 (Sunday) 12:55
40D: Custom WB questions
aparis99
Apr 26, 2009 12:55 |  #1
1.) I've got a grey card thats the size of a credit card. Does it have to fill the frame? I've seen some people just have models hold a larger one next to their head but i dont know if they fill the frame or not.
2.) Is there a way to set the Custom WB and find out what temperature it's set to? I've seen the Sony DSLR's tell u but I cant seem to find out on the 40D, all the WB info just says custom
My Site - www.apimagery.com (external link)
Canon R5 (x2), Canon RF 15-35 f/2.8L IS, Canon RF 24-70 f/2.8L, Canon RF 70-200 f/2.8L, Canon RF 100-500L, Sigma Art 35 f/1.4, Canon 85 f/1.8, Canon 100 f/2.8L Macro
Steve-R
Apr 26, 2009 21:00 |  #2
The manual says that the object you are using for custom WB only has to fill the spot metering circle.
There is no way that I know of to find out the equivalent temperature of a custom WB. I'm not sure that it is even possible in all situations. For example, if your WB correction includes a large green component.
Steve
Canon 70D,
10-22, 28-105, 70-300 f/4-5.6, 100 f/2.8
Tamron 17-50 f/2.8, Tokina 10-17 Fisheye, Tokina 35 f/2.8
svarley
Apr 27, 2009 01:24 |  #3
I just take a picture and when i get it into Lightroom, use that little eyedropper on the gray card to set the WB. Of course, it's after the fact but you can see the temperature & green/megenta cast from there and then sync all your pics to that setting.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Apr 27, 2009 04:26 as a reply to  @ svarley's post |  #4
When fixing things after the fact, RAW format is your friend.
Anders
colin15
May 09, 2009 05:40 |  #5
[QUOTE=Steve-R;7809367]The manual says that the object you are using for custom WB only has to fill the spot metering circle.
Excuse the newbie question but after reading the manual it does not mention what f/stop or shutter speed you should use or whether a flash should also be used
johnz
May 09, 2009 05:43 |  #6
It depends on the settings that your going to use when taking The actual pic. If your using a flash, then you must do the custom wb adjustments with flash too.
- Tuomas Gustafsson
My smugmug (external link) - ( still on the works )
My gear list/ DOF calculator for Nokia phones
With Canon you can... spend all your money on glass.
colin15
May 09, 2009 06:44 |  #7
[QUOTE=johnz;7887318]I​t depends on the settings that your going to use when taking The actual pic. If your using a flash, then you must do the custom wb adjustments with flash too.[/quote
In that case when you use the gray card to set up the custom white balance should you set the white balance to auto to take the shot?
krb
May 09, 2009 12:23 |  #8
[QUOTE=colin15;7887440​]
johnz wrote in post #7887318 (external link)
It depends on the settings that your going to use when taking The actual pic. If your using a flash, then you must do the custom wb adjustments with flash too.[/quote
The camera cannot read your mind. When you use a grey card to set a custom WB you have to set the WB to custom to use that value. If you set WB to auto then you are telling the camera to make it's own guess at the correct WB.
-- Ken
Gear list
apersson850
Gallery: 35 photos
May 09, 2009 14:51 as a reply to  @ krb's post |  #9
On the other hand, which white balance you used when you actually took the shot that defines the custom white balance doesn't matter. You just go in and select one image, then sets the camera to custom white balance to actually use that definition of what's white.
Anders
1,612 views & 0 likes for this thread, 7 members have posted to it.
1458 guests, 137 members online
