Has anyone had trouble converting RAW files to DNG. I am using CS4(Bridge) and a Seagate 1TB external with a MBP. My old HD was fine, ( Exact same model) but this one is cooking my Mac, running at 190 degrees to convert about 4 gigs.
Any Ideas?
mikeassk Goldmember 2,329 posts Likes: 3 Joined Aug 2006 Location: San Diego/ San Fran/ Berkeley More info | Apr 27, 2009 01:06 | #1 Has anyone had trouble converting RAW files to DNG. I am using CS4(Bridge) and a Seagate 1TB external with a MBP. My old HD was fine, ( Exact same model) but this one is cooking my Mac, running at 190 degrees to convert about 4 gigs.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Apr 27, 2009 01:22 | #2 If you're working it hard and it doesn't have a fan it'll get hot. I can't be bothered converting to American units so I can't really tell you if that's too hot or not. Probably is though. Point a fan at it or something, or get a better drive. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
mikeassk THREAD STARTER Goldmember 2,329 posts Likes: 3 Joined Aug 2006 Location: San Diego/ San Fran/ Berkeley More info | Apr 27, 2009 01:38 | #3 It is about 88 centigrade.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Apr 27, 2009 01:45 | #4 My hard drives are 38 celcius, 60 degrees is as hot as they're meant to get. Do you have plenty of room around the external drive for cooling? Does it have a fan, and if so is it working? Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
mikeassk THREAD STARTER Goldmember 2,329 posts Likes: 3 Joined Aug 2006 Location: San Diego/ San Fran/ Berkeley More info | Apr 27, 2009 02:01 | #5 |
Moppie Moderator 15,102 posts Gallery: 24 photos Best ofs: 1 Likes: 451 Joined Sep 2004 Location: Akarana, Aotearoa. (Kiwiland) More info | Apr 27, 2009 02:04 | #6 The CPU is hitting 88 deg? flickr
mikeassk THREAD STARTER Goldmember 2,329 posts Likes: 3 Joined Aug 2006 Location: San Diego/ San Fran/ Berkeley More info | Apr 27, 2009 02:15 | #7 ^
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Apr 27, 2009 04:29 | #8 Strange. I guess it's just working that little bit harder, and laptops are pretty compact. 88 degrees is pretty hot for a cpu though. Make sure the sides and bottom of the laptop aren't obstructed, make sure it's on a hard flat surface, but there's not much else you can do. If it's multi-core tell it to run using only one core to keep the temp down, and run it overnight - the air's cooler then too. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
| Latest registered member is semonsters 1052 guests, 103 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
