Thread started 28 Apr 2009 (Tuesday) 06:15
Slave for EX Speedlights
tmonatr
Apr 28, 2009 06:15 |  #1
I recently purchased THIS (external link) optical slave from FlashZebra. It is compatible with EX flashes, most others are not. I wanted a way to fire my 2 430EX flashes without having to purchase another Cybersync receiver. I received it very quickly and am happy to say it works perfectly. I use it in the #0128 hotshoe adaptor that is listed in the above link. It's an inexpensive way to fire a 2nd flash.:D
Tim
Bartender - "So, you guys are dictionary salesmen."
Roy Munson - "You would be punctilious in assuming that."
bobbyz
Apr 28, 2009 08:53 |  #2
Does it work outside? Even inside when you got more than you shooting it is going to get triggered by other flashes.
Fuji XT-1, 18-55mm
tmonatr
Apr 28, 2009 09:03 |  #3
bobbyz wrote in post #7818425 (external link)
It probably won't work outside and, of course, the slave can't tell which flash is yours, but I got it for portrait lighting, when I will be the only one shooting. For that it will be perfect.
Tim
bobbyz
Apr 28, 2009 09:06 |  #4
Thanks.
Fuji XT-1, 18-55mm
agedbriar
Apr 28, 2009 13:32 |  #5
I have FlashZebra Item #0118, the PC connector version.
Of course, they have the obvious limitations all optical slaves have, except that they are compatible with EX flashes, while generic optical slaves aren't.
1,030 views & 0 likes for this thread, 3 members have posted to it.
Latest registered member is heidiro
1310 guests, 110 members online
