Thread started 28 Apr 2009 (Tuesday) 20:44
100-400mm HALLELUJAH Thank you Thank you Kiss Kiss Kiss
khall
Apr 28, 2009 20:44 |  #1
I have the 100-400mm and have not really been happy with it when hand holding. (It's great on a Mono pod) The reason was I didn't like the push/pull and couldn't seem to find the right tension for it.
I was in this part of the Forum and came across a thread in which one member said, that when used this lens he turned the tripod collar to the top of the lens barrel. The difference this makes is fantastic it's so much easier to hold and to zoom in and out.
Not now sure which thread it was or who made the comment but Thank You very much for the tip, you've now made me a very happy 100-400mm owner.
Thanks again :) :)
YNWA.
joeseph
"smells like turd"
Gallery: 258 photos
Joined Jan 2004
Apr 28, 2009 23:16 |  #2
would it be useful to suggest taking the collar off altogether & saving some weight as well?
TF posting: here :-)
Vascilli
Apr 28, 2009 23:26 |  #3
Only if you don't plan on using a monopod or tripod.
Flickr (external link) | Gear List
thatkatmat
Gallery: 41 photos
Apr 28, 2009 23:33 |  #4
joeseph wrote in post #7823211 (external link)
I shoot mostly hand held, just about the first thing I do is take off the collar and put it in the box on any long lens, not sure if it really makes much of a difference but my brain thinks it does:D
My Flickr (external link)
Stuff
khall
Apr 29, 2009 00:27 |  #5
I use it on a Mono pod when taking Rugby shots as it get a wee bit heavy after 2 or 3 games, but its so easy just to turn the mount up to the top and get it out of the way, plus it only takes seconds. As you gather I'm very pleased with the tip from?
YNWA.
KenjiS
"Holy crap its long!"
Gallery: 612 photos
Apr 29, 2009 00:38 |  #6
thatkatmat wrote in post #7823314 (external link)
Same here, I felt stupid however when i tried to remove the 100-400's tripod collar the first time..I had no clue how it came off!
Deviantart (external link)
Electrical
Apr 29, 2009 06:30 |  #7
KenjiS wrote in post #7823666 (external link)
same here, still stuck. enlighten me?
Kuma
Apr 29, 2009 06:40 |  #8
I haven't been doing this but I might give it a try. :D
RyanHutchinson
Apr 29, 2009 10:17 |  #9
Electrical wrote in post #7824425 (external link)
if its the same as the 300 f4, you lossen the nut on the collar, and slide it off the back of the lens, the lens has to be off the body.
KenjiS
Gallery: 612 photos
Apr 29, 2009 12:21 |  #10
Loosen the nut, rotate it around, theres a red dot on the tripod collar that matches the red dot on the lens, line them up, and pull it
It bayonets on..sorta...
Pete
Apr 29, 2009 12:23 |  #11
khall wrote in post #7822345 (external link)
Thanks again :) :)
:D
I think that could have been me. I usually have my tripod collar facing upward and I seem to remember posting about it to someone complaining about the discomfort. It makes a handy carry-handle that way around as well... :D
Pete
UK SE Catch of the Day
khall
Apr 29, 2009 18:13 |  #12
Yes Pete it more than likely was you as in the post I did also read about using it as a carry-handle.
Again thanks a million it really is a much nicer lens to hold now, cant believe how simple things like that can make such a huge difference. :) :)
YNWA.
2,886 views & 0 likes for this thread, 9 members have posted to it.
Latest registered member is Dannal01
803 guests, 121 members online
