Thread started 29 Apr 2009 (Wednesday) 04:21
RRS Drag Knob
WillOPhotos
Apr 29, 2009 04:21 |  #1
Hey People of POTN, Just recieved my RRS BH-55 Ballhead yesterday and im wondering if this is normal with the Drag knob, when I turn it towards 0 I can still turn it till between 8-7 and when I turn it right around to 9 it goes past till between 0-1, Hopfully you guys will understand what I mean.
Cheers
Will.
Hassy H4D-40, Gitzo 3541XLS, RRS BH-55
http://www.flickr.com/​photos/willophotograph​y/ (external link)www.williamophuis.com/​blog << add blog for some reason it goes to my main site :) (external link)
harv3589
Apr 29, 2009 12:49 |  #2
Just checked mine and it does the same...
WillOPhotos
Apr 29, 2009 17:43 as a reply to  @ harv3589's post |  #3
thanks for the reply, so it seems this is normal, few more peoples comments would be good :)
MDJAK
Apr 29, 2009 19:40 |  #4
I'm not sure what you mean, but I will say the drag knob is the weak spot of this ballhead. It controls the drag poorly, and at least on mine, the numbers are very hard to see. It seems that it must be turned very tight for the drag to hold a heavy lens.
WillOPhotos
Apr 30, 2009 03:23 as a reply to  @ MDJAK's post |  #5
yeah thats what I find, What I mean is you think 9 is the tightest but my knob will keep turnin till 2 lol not a big deal Because I wont use the drag much just wondering if it was normal.
jmik26
Apr 30, 2009 09:19 as a reply to  @ WillOPhotos's post |  #6
I don't even use my drag knob, I leave it as loose as possible. If I let go of my setup I make sure the main knob is cranked down. Don't wanna take a chance of all that weight flopping forward....Jeff
www.jmikosphotography.​com (external link)
Moonjo
Apr 30, 2009 15:24 as a reply to  @ jmik26's post |  #7
I have the BH-40, but the drag knob is the same concept as the BH-55. The way I understand it is you need to crank down the drag knob until you get the right tension for your setup. That might mean turning the knob several times past 9. Once you find the tension you like then you use the numbers to remember what that setting is.
At least that's the way I do it for my ballhead. :P
EOS R5 BG-R10 | EOS R5 | Canon RF70-200 f/2.8L IS | Canon RF24-70mm f/2.8LIS | Canon EF100mm f/2.8LIS | Canon EF135mm f/2.0L | Canon EF85mm f/1.2L II | Canon EF24-105 f/4.0L IS | 580EX II.... and other lighting stuff
Facebook (external link)
1,207 views & 0 likes for this thread, 5 members have posted to it.
RRS Drag Knob
1466 guests, 173 members online
