It works and never lies!
John_T Goldmember More info | Apr 30, 2009 18:51 | #1 It works and never lies! Canon : EOS R : 5DIV : 5DS R : 5DIII : 7DII : 40 2.8 : 50 1.4 : 35L : 85L : 100L IS Macro : 135L : 16-35L II : RF-24-105L IS : 70-200L II : 100-400L IS II : 1.4x & 2x TC III : 600EX-RT : 580EX : 430EX : G1XII : Markins Q10 & Q3T : Jobu Gimbal : Manfrotto Underware : etc...
Apr 30, 2009 18:59 | #2 Playing with the Toys....... Nikon D810 Nikon 50F/1.4G - Nikon 70-200F/2.8II
leroy_sunset Senior Member 679 posts Joined Oct 2008 Location: Olympia, WA More info | Apr 30, 2009 20:07 | #3 Awesome. Canon's Jurassic Park - 1Ds, 1D bodies
JeffreyG "my bits and pieces are all hard" More info | Apr 30, 2009 20:25 | #4 I MA set my 1D3 with a simple set of three batteries, and I never took a picture. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
Quad Goldmember 1,872 posts Likes: 3 Joined Nov 2005 More info | Apr 30, 2009 21:05 | #5 JeffreyG wrote in post #7835067 Both my 50/1.4 and 50/2.5 CM showed so much shot to shot error that entering any MA number seemed fruitless. All of the ring USM lenses I have were much more consistant.
JeffreyG "my bits and pieces are all hard" More info | Apr 30, 2009 21:16 | #6 Quad wrote in post #7835275 My 50/1.4 was like that a bit but my 35/1.4 was far worse especially at about 3 metres. Strange that, My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
Quad Goldmember 1,872 posts Likes: 3 Joined Nov 2005 More info | Apr 30, 2009 21:53 | #7 JeffreyG wrote in post #7835345 Strange that, I have seven ring-USM lenses and two non-ring USM lenses. My ring USM: 35L 85L II 135L 300/4L 17-40L 24-105L 70-200/2.8L IS All of these lenses focussed consistently over and over when I set up my MA. I also set up the 135L, 70-200/2.8 and 300/4 with my 1.4X TC. Strange and rather annoying. They are the two lenses I have the hardest time focusing manually as well. At least consistently. In day to day work their autofocus does works fine enough. It is just in a test situation if I activate the autofocus they do not always settle in the same spot.
Ziffle Goldmember 1,896 posts Likes: 2 Joined Sep 2008 Location: Big "D" - Texas More info | Apr 30, 2009 22:03 | #8 Sweet! _______________
RichS Goldmember 2,352 posts Joined Nov 2008 Location: N. California More info | May 01, 2009 01:32 | #9 It looks like you are pointing in the center on a 45 degree angle ? How far away ......I Can't Paint....So I Do This........
May 01, 2009 02:11 | #10 Rich S wrote in post #7836495 It looks like you are pointing in the center on a 45 degree angle ? How far away 'bout 5-10 cm more than each lens's minimum focusing distance, AF center point only, assist points turned off, a variation on the Tim Jackson method. Tripod, cable release, lens center point at the height of the 15 on the ruler, focal plane parallel to the target. Canon : EOS R : 5DIV : 5DS R : 5DIII : 7DII : 40 2.8 : 50 1.4 : 35L : 85L : 100L IS Macro : 135L : 16-35L II : RF-24-105L IS : 70-200L II : 100-400L IS II : 1.4x & 2x TC III : 600EX-RT : 580EX : 430EX : G1XII : Markins Q10 & Q3T : Jobu Gimbal : Manfrotto Underware : etc...
symby Member 134 posts Joined Apr 2008 Location: Halifax, NS More info | May 01, 2009 08:02 | #11 Are you going to try from a bit farther away as well? not just at MFD + a little bit? Or do you think that would matter? Canon 50D | Canon XTi | Canon 50 f/1.8 | Tamron 17-50 f/2.8 | Canon 70-200 f/4L IS | Sigma 10-20 | Canon 430EX
versedmb Goldmember 4,448 posts Likes: 4 Joined Apr 2006 More info | May 01, 2009 08:07 | #12 symby wrote in post #7837342 Are you going to try from a bit farther away as well? not just at MFD + a little bit? Or do you think that would matter? I've found that evey Canon dSLR that I've ever owned has the most difficulty accuratetly focusing close to MFD, so I often MF when I know I'm close to MFD. Gear List
shimmishim Goldmember 1,602 posts Joined Oct 2007 Location: Knoxville, TN More info | May 01, 2009 08:20 | #13 symby wrote in post #7837342 Are you going to try from a bit farther away as well? not just at MFD + a little bit? Or do you think that would matter? i've learned not to MA at the MFD. The reason why is because even if you're able to get it tack sharp here, the added effects of the MA will be seen at farther distances. Call me John | JSP Blog
symby Member 134 posts Joined Apr 2008 Location: Halifax, NS More info | May 01, 2009 09:55 | #14 ^^ That makes more sense to me. Canon 50D | Canon XTi | Canon 50 f/1.8 | Tamron 17-50 f/2.8 | Canon 70-200 f/4L IS | Sigma 10-20 | Canon 430EX
Doing the microadjustments at a set distance does not guarantee that they will be as impressive at a longer distance. The things you do for yourself die with you, the things you do for others live forever.
| Latest registered member is semonsters 1477 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
