Thread started 02 May 2009 (Saturday) 22:20
Rant: Why Canon UWA sucks
joe ­ mama
May 02, 2009 22:20 |  #1
I think this is my third "Rant" thread. Let me know if I've used them all up. : )
Anyway, check this out:
http://forums.dpreview​.com …rum=1018&messag​e=31752380 (external link)
Horrific. If Canon cannot make a UWA that has sharp corners at 16mm f/2.8, then what's the point of f/2.8? : )
Seriously, this is why I rarely take claims about lens performance seriously, unless pics accompany the claims. I've even seen people post pics with motion blur and/or camera shake and blame the lens.
And, of course, it does cut both ways. I've seen claims that such-and-such is "razor sharp", which sounds good, until you see the pics. So, sure, some lenses have issues, some lenses are great, but without a pics and EXIF, who knows what to make of a claim?
--joe
www.josephjamesphotogr​aphy.com (external link)
www.pbase.com/joemama (external link)
BigBlueDodge
May 02, 2009 22:27 |  #2
Well, I think Canon is weak in the UWA department, and it appears they know it as witnessed by them releasing "new & improved" versions of the 14mm, 16-35mm, and 24mm lenses in the last couple of years. The new versions do appear to improve corner performance, but I'm not sure put them in the same league as the Nikon 14-24, for example.
The "traditional" argument I've heard many times on this forum, is that you typically stop down when using a UWA and thus, wide open corner performance is not critical. I tend to shoot wide open, and thus do want wide open corner performance. The link you posted is the MK 1 version of the 16-35. From comparisons I've seen, the MKII version is much better. Is the picture posted in your link representative of all 16-35 MKI ? Well I certainly hope not as that is a very poor performance.
David (aka BigBlueDodge)
Gear
M3Rocket
May 02, 2009 23:26 |  #3
Well, nothing is in the Nikon 14-24 G league. It's obliterating even the well-known primes in it's range.
As already pointed out, that's the original version. And by the looks of it, a bad one at that. Even my 17-40 is better, let alone the II.
iLUKphotography (external link)
WillOPhotos
May 03, 2009 02:48 as a reply to  @ M3Rocket's post |  #4
lol thats horrible! my 16-35 is nothing like that!
Hassy H4D-40, Gitzo 3541XLS, RRS BH-55
http://www.flickr.com/​photos/willophotograph​y/ (external link)www.williamophuis.com/​blog << add blog for some reason it goes to my main site :) (external link)
PKSmith
May 03, 2009 03:13 |  #5
I don't know much about UWA's, but I do see green fringing, which is usually a sign of missed focus. However, the corners are even worse than the center, so I'm guessing that there is something majorly wrong with that copy of the lens.
| Rebel XSi | EF-s 18-55 f/3.5-5.6 IS | EF 50 f/1.4 | EF 70-200 f/4L | Speedlight 199A |
The ­ Fox
May 03, 2009 03:16 |  #6
But doesn't the ultra wides have lots of distorsion in the corners more then the center?
PS- The 10-22mm I am holding has amazing corners wide open.
Nick
"I work from awkwardness. By that I mean I don't arrange things. If I stand in front of something, instead of arranging it, I arrange myself" -Diane Arbus
EOS R6 Gripped | 7D MK II Gripped | 24mm F1.4 | 35mm F2 IS | 24-70mm F2.8L | 70mm F2.8 Macro | 135mm F2L | 70-200mm F4L IS |
LBaldwin
May 03, 2009 03:50 |  #7
Every manufacturer, has a weakness in it;s product lines. Canon's is to an extent, WA or UWA. UWA was not that big a market except for the last few years. Remember that 95% of working photographers never went below 20mm so a 16 or even a 14 was unheard of in most circles. Superwides were specialty cameras or lenses depending on format and usually they were rented for onetime shoots. If a newspaper had one it was because they had a budget for exotic stuff and got them. Long teles were not considered exotic for most pros work.
So cameras like Leica, Hasselblad, and other niche cameras had those markets sewed up. You just rented what you needed. But today with various formats or chip sizes, the camera companies had to put their emphasis in the areas that made the most money, sports...
Les Baldwin
http://www.fotosfx.com (external link)
Tom ­ W
Canon Fanosapien
Joined Feb 2003
May 03, 2009 05:59 |  #8
WillOPhotos wrote in post #7847987 (external link)
Indeed, that copy is hosed! My original 16-35 had some softness in the corners at f/2.8, but nothing like that. I'd send that one in to Canon. The Mk II version is very good in that respect.
Anxiously awaiting the results of the new 17 mm tilt/shift. That could be an interesting lens.
Tom
5D IV, M5, RP, & various lenses
timnosenzo
May 03, 2009 06:06 |  #9
joe mama wrote in post #7847064 (external link)
Let's be realistic though, the picture posted in that thread is not representative of most 16-35's. This guy either dropped his, or got a REALLY bad one. The one I had was certainly a lot better than that.
Double ­ Negative
*sniffles*
May 03, 2009 07:34 |  #10
That lens is clearly b0rked. It's not a Canon *design* fault, just a bad copy.
I don't think Canon UWA lenses are all that bad. Look at the 14L and 24L; both sweet lenses. Though honestly if I need something stupid wide and need really sharp, distortion free - even in the corners - I'll use my Zeiss 4/18 Distagon ZM. The 14L comes close, stopped way down (Mark I). The 16-35 Mark I definitely had some corner issues though. But again, that's not the problem in the linked discussion/image.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
dithiolium
May 03, 2009 07:38 |  #11
So we should get a D700 + 14-24 and a 5DII + 70-200/2.8
Strange women lying in ponds distributing swords is no basis of a government
Gear List / Flickr (external link)
1,857 views & 0 likes for this thread
Latest registered member is Cut Out Way
854 guests, 270 members online
