When ever I edit my photo's in CS2 I loose ethe EXIF data of my photo's?
I usually shoot in raw and have to convert my images into .DNG's using Adobe NG convertor.
So any ideas's anyone?
Phil
penfolduk Senior Member More info | May 04, 2009 05:10 | #1 When ever I edit my photo's in CS2 I loose ethe EXIF data of my photo's? Fuji X-T3
jbimages Senior Member 492 posts Joined Mar 2007 Location: Sydney, Australia More info | May 04, 2009 07:19 | #2 Why do you think the data is lost? John
May 04, 2009 09:41 | #3 using opanda powerexif Fuji X-T3
dalto Senior Member 758 posts Likes: 16 Joined Apr 2009 Location: Austin, TX More info | When do you lose the EXIF? Do you have it after you convert to DNG? Does it go away after converting to JPEG or something else?
jgrussell Looking around nervously 18,758 posts Likes: 14 Joined May 2008 Location: NJ USA More info | May 04, 2009 09:51 | #5 penfolduk wrote in post #7854087 When ever I edit my photo's in CS2 I loose ethe EXIF data of my photo's? I usually shoot in raw and have to convert my images into .DNG's using Adobe NG convertor. So any ideas's anyone? When are you checking the EXIF? If it's after saving, and you do a Save for Web, that's what's stripping the EXIF out. -- jgr
May 04, 2009 12:46 | #6 That will be it then! Fuji X-T3
ChasP505 "brain damaged old guy" 5,566 posts Likes: 1 Joined Dec 2006 Location: New Mexico, USA More info | You select Save As and choose which file format from the drop down list-- Tif, JPG, PSD, etc. If you choose JPG, you will also be asked to select the level of compression. Chas P
| Latest registered member is griggt 1306 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
