Thread started 05 May 2009 (Tuesday) 15:36
Would this work?
Krapo
May 05, 2009 15:36 |  #1
I currently have a Macbook and a home PC. I use LR2 on both (but don't share the libraries).
I would like to buy a new Mac to replace the PC, and I'm planning to use the PC as a file (and multimedia) server.
My requirements are the following:
- Use LR2 on both Mac and share a common library that would sit on the server
- Back-up files from both Mac on the server using Time Machine
- Have the server set-up in RAID
My questions:
- Will it be too slow to run lightroom Libraries from the server through Wi-Fi (alternatively Ethernet)?
- Are there limitations from the fact that the server runs Windows (XP)?
- Is there an issue with Time Machine running in a RAID configuration?
Sorry for these questions that may come across as naive, but I am not a Mac/PC interconnectivity expert.
Many thanks in advance!
François
40D + grip, 70-200 f/2.8L IS, 24-70 f/2.8L, 17-40 f/4L, 50 f/1.4, 580 EX II
www.casualvision.com (external link)
Tony-S
May 05, 2009 17:22 |  #2
I think OS X will do what you want pretty easily. I don't know about LR and sharing libraries, though (I use Aperture).
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
MaxxuM
May 05, 2009 21:02 |  #3
Krapo wrote in post #7864063 (external link)
My questions:
1. Depends on what you think slow is and how big these library's are. It's been a while since I've used LR so I would advise against it unless you use at the very least gigabit (wired) connections. You need sustained bidirectional connections.
2. There are many limitations to using regular ol' XP, but you may not run into any. The first is a limit of only 10 connections at once (some programs will open up more than one connection at a time to). If all you're doing is moving files around then there shouldn't be much of an issue. There will also be pretty weak security.
3. As far as I can remember you cannot use shared folders for Time Machine. You'd have to use a direct connection to your Mac's or use a Time Capsule. I've heard of people using NAS/Windows Shares but I also heard it had mixed results. Maybe they will add this feature in 10.6.
In2Photos
May 06, 2009 07:23 as a reply to  @ MaxxuM's post |  #4
I don't think you can run LR with the library on another machine. It needs to be local. You could, however, keep your photos on the server and sync your libraries on each machine. Just remember not to use LR on both machines at the same time, both for legality and the safety of your library!
Current Gear and Feedback
Krapo
May 10, 2009 05:17 |  #5
Thank you for your replies. Sorry I didn't reply before, I was working abroad.
It seems indeed that it is difficult to have Time machine on a NAS, although it is feasible via a rather geeky set of instructions.
Mike, how exactly would you synchronize LR libraries with the photos sitting on the server? I guess I'm a bit thick, I don't really get it.
François
In2Photos
May 10, 2009 09:04 |  #6
Krapo wrote in post #7892109 (external link)
You could use a piece of software that checks the two locations and updates the appropriate library that is "out of date". I am not sure what software on a MAC would do this however.
imahawki
May 10, 2009 09:16 |  #7
I ran LightRoom with the files on a network drive but the library was on my local machine (as it has to be at this point, unless there is some work around). It was dreadfully slow, to the point of forcing a PC upgrade for me.
Olympus OMD E-M10 | Olympus 25 f/1.8 | Olympus 45 f/1.8 | Olympus 75 f/1.8 | Olympus 9-18 f/4-5.6 | Olympus 14-42 f/3.5-5.6 | Olympus 40-150 f/4-5.6
My Zenfolio Gallery (external link)
Krapo
May 10, 2009 11:54 |  #8
In2Photos wrote in post #7892688 (external link)
This makes sense. I'll do some research to find a software which does that.
François
Krapo
May 10, 2009 11:57 |  #9
imahawki wrote in post #7892736 (external link)
Was it better after the upgrade? Was it slow because of the fact that your photos were on a remote server? Did you use wireless or cable network?
François
imahawki
May 10, 2009 14:03 |  #10
Now the photos and library are on local SATA II drives so it is extremely fast. Before the files were on a USB 2.0 drive being shared. I used both wireless and Gigabit Ethernet but even with GigE it was orders of magnitude slower than what it is now.
1,016 views & 0 likes for this thread, 5 members have posted to it.
Would this work?
1332 guests, 139 members online
