Thread started 05 May 2009 (Tuesday) 20:19
Panorama Tripod and Mount Search
TheFloridaShooter
May 05, 2009 20:19 |  #1
I'm looking for a middle of the road quality tripod and camera mount to do panarama shots. The reason I'm leaning towards the middle of the road in quality is it's going to be left in a vehicle. I'd like it to be easy to setup/level a heavy 50D w/ grip and up to a 70-200 2.8 IS lens. And assistance would be helpful.
1Dx MKII | 1Dx | 5D MKIV | 5D MKIII | 5Ds r | 5Ds | 7D MKII | 7D | G16 | G3x | EOS M & M3 | 800 f5.6 | 600 f4 | 400 f2.8 | 300 f2.8 | 200-400 f4 | 100-400 f4.5 - 5.6 II x 2 | 70-200 f2.8 | 14 f2.8 II | 50 f1.2 | 50 1.4 | 85 f1.2 | 135 f2 | 24-70 f2.8 II | 11-24 f4 | 35 f1.4 II | Pentax 645Z | SMC Pentax-DA 645 25mm F4 AL | SMC Pentax-D FA 645 55mm F2.8 AL | Pentax 90mm f/2.8 D FA 645 Macro ED AW SR | SMC Pentax-D FA 645 200mm f/4 IF | SMC Pentax-D FA 645 300mm f/4 ED IF | SMC FA 645 400mm f/5.6 ED IF Lens
Quad
Joined Nov 2005
May 05, 2009 20:39 |  #2
Check out manfrotto. They are decent tripods I had one for about 25 years before I finally replaced it and I only did that because I could afford a carbon fiber one. That thing used to get put on airplanes just tied up and tagged.
I prefer 3 way pan heads but most (and by most I think everyone else) people here like ball heads. I think to get a good ball head you need to spend a fair bit more money so I would say that is another good reason for a 3 way pan head.
I like a right angle camera mount. I made my own with some 1.5 inch aluminum flat and added an rc2 quick release to it. It will help to keep the weight of the camera more balanced on the tripod and with a middle tripod that is even more important. If you make one it could be very inexpensive, depending on if you have some scrap metal around.
5teve
May 05, 2009 20:57 as a reply to  @ Quad's post |  #3
I did some research but was unable to find an inexpensive panoramic head so I made my own.
https://photography-on-the.net/forum/showthre​ad.php?t=679708
5D2 | 35 f/1.4 L | 24-105 f/4 L IS | 70-200 f/2.8 L IS II | 580EXII | Sony RX100-III
TheFloridaShooter
May 05, 2009 21:13 |  #4
FYI I'm not interested in the 360 degree stuff , just stitching a few pictures together. I'm under a little pressure here as I'm heading east the first part of June.
TheFloridaShooter
May 05, 2009 21:15 |  #5
Steve,
I'll look at your link tomorrow. Would yours work for what I'm after?
Quad
Joined Nov 2005
May 06, 2009 11:48 |  #6
With tele lenses you do not have to be very concerned with having the lens over its proper focus point as that helps mostly with foreground objects and you will not have so much in the foreground with a long lens. The zoom lens will also likely change that point as you change focal lengths. Also since it has a tripod mounting bracket you really do not need the right angle mount.
That said here is a photo of my simple right angle adapter that is also set back for one of my pan primes the 24TSE (actually it is 1mm out) it is just 4mm out for my 45 and that is close enough for that lens except indoors with close foreground objects. You can use this sort of thing for short lenses you want to use. You just need to figure out how far back to set the camera body in relation to the lens. I used a macro focus rail but I had one and if you don't have a regular use for it you probably don't want to buy it just for this. Of course you could use one for pans as well using it to change the lens position depending upon what lens you are using.
Inspeqtor
Chet,You are a genius
Gallery: 87 photos
May 06, 2009 12:13 as a reply to  @ Quad's post |  #7
I have the Manfrotto Head RC4 shown HERE (external link). It is nice because it has 2 bubble levels. One to make sure the tripod is level, the second to make sure the camera is level from the tripod mount so when you rotate the RC4 head you are moving perfectly horizontal.
Charles
Canon EOS 90D * Canon EF-S 18-135mm f/3.5-5.6 IS * Flickr Account (external link)
Tokina AT-X Pro DX 11-20 f/2.8 * Sigma 17-70 f2.8-4 DC Macro OS * Sigma 150-500 f5-6.3 APO DG OS HSM
Canon 18-55 IS Kit Lens * Canon 70-300 IS USM * Canon 50mm f1.8 * Canon 580EX II
René ­ Damkot
May 07, 2009 09:59 |  #8
IMO RC4 is (way) too big on a DSLR.
RC0 is *way, way* too big.
RC2 is okay size wise.
That being said: I prefer Arca Swiss style QR. ;)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
1,210 views & 0 likes for this thread
Latest registered member is smarshall1
1622 guests, 314 members online
