Help! how do I check ink levels on iP4600 printer?
safetyman Mostly Lurking 17 posts Joined Aug 2007 More info | May 08, 2009 05:29 | #1 Help! how do I check ink levels on iP4600 printer?
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | May 08, 2009 18:12 | #2 For my ip4000, the utility program will check, which allows you to clean jets, etc. Ordinarily I do not bother to check with that program, as the levels are displayed with a notification when any color gets low...the printer can do a lot of printing before 'low' turns into 'empty' for that color, so when it first appears it is simply a notification the need to buy ink if you don't already have some on hand when the tank is truly empty. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
May 10, 2009 04:27 | #3 Hi! Wilt thanks for your information,will try it. Problem arose because I have always used Epson in the past.
Salleke Goldmember 2,201 posts Likes: 2 Joined Feb 2005 Location: Belgium More info | May 10, 2009 11:43 | #4 safetyman wrote in post #7881129 Help! how do I check ink levels on iP4600 printer? When you have finised installing Canon Software you will see a Icon on your
Thanks Salleke, will do.
| Latest registered member was a spammer, and banned as such! 1794 guests, 117 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
