I have a 18-55, I like the fish-eye look. Is it worth my investment to get a fish-eye? How often do ya'll use yours?
Thanks.
tawcat Senior Member 433 posts Joined Mar 2009 Location: Cammack Village, Arkansas More info | May 09, 2009 13:43 | #1 I have a 18-55, I like the fish-eye look. Is it worth my investment to get a fish-eye? How often do ya'll use yours? Yes, a picture really is worth a thousand words!
canonnoob Cream of the Crop 8,487 posts Likes: 1 Joined Aug 2008 Location: Atlanta, GA More info | May 09, 2009 13:46 | #2 why not just get an ultra wide angle... that would be fine... say the 10-22. David W.
FlyingPhotog Cream of the "Prop" 57,560 posts Likes: 178 Joined May 2007 Location: Probably Chasing Aircraft More info | May 09, 2009 13:48 | #3 A true 180 degree fish eye lens is really a specialty tool and you have to pick your spots where it's appropriate. Jay
edrader "I am not the final word" More info | May 09, 2009 13:52 | #4 FlyingPhotog wrote in post #7888935 A true 180 degree fish eye lens is really a specialty tool and you have to pick your spots where it's appropriate. For just generally wanting to shoot really wide, Dave is right, get an UWA lens instead. the fisheye turned me on to UWA. after tiring of the fisheye i bought the 16-35L II and now use it alot on my FF camera. http://instagram.com/edraderphotography/
joemama Senior Member 666 posts Joined Oct 2005 Location: Earth More info | May 09, 2009 14:00 | #5 Permanent banIn my opinion, a fisheye often has a much more natural, and appealing, look than a wide rectilinear. The reason is because the fisheye projection preserves distance at the cost of not preserving parallel, whereas a rectilinear preserves parallel at the expense of not preserving distance. --joe
nuffi Senior Member 926 posts Joined Nov 2008 More info | May 09, 2009 14:09 | #6 Joe Mama, thanks for this post. When I opened this thread I was wondering about just this very info!
nureality Goldmember 3,611 posts Likes: 1 Joined Jan 2008 More info | May 09, 2009 14:12 | #7 I have a Circular FishEye that I'm quite fond of, but to be honest, I don't think I would have it and only 1 other lens (which your 18-55 IS is). Alan "NuReality" Fronshtein
nureality Goldmember 3,611 posts Likes: 1 Joined Jan 2008 More info | May 09, 2009 14:23 | #8 joe mama wrote in post #7888990 In my opinion, a fisheye often has a much more natural, and appealing, look than a wide rectilinear. The reason is because the fisheye projection preserves distance at the cost of not preserving parallel, whereas a rectilinear preserves parallel at the expense of not preserving distance. What that means is that, while parallel lines will converge with a fisheye, there is no stretching at the edges, whereas with a rectilinear, the lines remain parallel, but the edges get stretched. If you keep the horizon centered, a FE pic can look remarkably normal, but other times you specifically want that FE look. Anyway, I use my 15 / 2.8 FE on a 5D quite a bit, and, in fact, consider it a "must-have" lens: http://www.pbase.com/joemama/15fegallery http://www.josephjamesphotography.com/RPWCC/ In the second link, the FE pics are primarily the tug-o-war and basketball pics, and, I have to say, simply no other lens would have done as well. That said, I really did love my 16-35 / 2.8L when I had it: http://www.pbase.com/joemama/1635 On crop, I would recommend a 10 / 2.8 FE over the 15 / 2.8 FE, though, if you still have an interest in a FE after seeing the pics. I look forward to the day I can add a 5D Mk2 to my gear list so I can add the Canon 15 f2.8 FE as well. I love how sharp that thing is at wide aperatures, the added isolation of your subjects in a fisheye composition reminds me of what I love so much about the Tokina 11-16 f/2.8 - isolating a subject very sharply and letting the rest of the very deep scene gently fade. Alan "NuReality" Fronshtein
tawcat THREAD STARTER Senior Member 433 posts Joined Mar 2009 Location: Cammack Village, Arkansas More info | May 09, 2009 14:42 | #9 Thanks to all that replied. Yes, a picture really is worth a thousand words!
luigis Goldmember 1,399 posts Likes: 3 Joined Jun 2008 Location: Buenos Aires, Argentina More info | May 09, 2009 15:07 | #10 If you look for a sharp fisheye for a crop body I strongly recommend the sigma 10mm 2.8 fisheye very fast, great AF and the thing is really sharp. www.luisargerich.com
nureality Goldmember 3,611 posts Likes: 1 Joined Jan 2008 More info | May 09, 2009 15:08 | #11 tawcat wrote in post #7889154 Thanks to all that replied. joe mama: Thanks so much for the info. The one thing I notice with the FE opposed to the 16-35, is that it appears the 16-35 has cleaner lines! Maybe a better edge finish? Because I don't know all the tech lingo, there are robably many better words to describe that. And I kinda agree that the use of FE may have to be pre-planned, whereas with UWA that Dave suggested might be a bit more useful. I really like the results of the 16-35, any samples with a 10-22? Thanks. one cannot discount the value of a good forum. The 16-35 f/2.8L is an awesome lens, but its also quite expensive (~$1600). But beware that @ 16mm its not that much wider than your 18-55 IS. You should look for shots from the Tokina 11-16mm f/2.8 if you're gonna go the UWA route. The Tokina 11-16 f/2.8 can be had for about $580 new and in the $500 range used. It will compliment the lens you already have in terms of adding to your focal range, you will find the IQ of the Tokina to be vastly superior to your 18-55IS tho, even when shooting wide open @ f/2.8. Alan "NuReality" Fronshtein
fanorama Member 209 posts Joined May 2009 More info | May 09, 2009 15:34 | #12 luigis wrote in post #7889270
Note: I've also used/owned a Peleng 8mm, a Canon 15mm 2.8, a Sigma 8mm and a Nikkor 10,5mm fisheye. Luigi +1 for sigma 10mm fisheye.. worth it!
joemama Senior Member 666 posts Joined Oct 2005 Location: Earth More info | May 10, 2009 01:43 | #13 Permanent bannuffi wrote: Joe Mama, thanks for this post. When I opened this thread I was wondering about just this very info!
nureality wrote: I look forward to the day I can add a 5D Mk2 to my gear list so I can add the Canon 15 f2.8 FE as well. I love how sharp that thing is at wide aperatures, the added isolation of your subjects in a fisheye composition reminds me of what I love so much about the Tokina 11-16 f/2.8 - isolating a subject very sharply and letting the rest of the very deep scene gently fade.
tqwcat wrote: joe mama: Thanks so much for the info. The one thing I notice with the FE opposed to the 16-35, is that it appears the 16-35 has cleaner lines! Maybe a better edge finish? Because I don't know all the tech lingo, there are probably many better words to describe that. And I kinda agree that the use of FE may have to be pre-planned, whereas with UWA that Dave suggested might be a bit more useful. I really like the results of the 16-35, any samples with a 10-22?
--joe
tawcat THREAD STARTER Senior Member 433 posts Joined Mar 2009 Location: Cammack Village, Arkansas More info | May 10, 2009 08:07 | #14 joe mama wrote in post #7891727 Hmm. I don't know what you mean by "cleaner lines" or "better edge finish". Perhaps you could explain in more detail, maybe by linking some comparative pics (feel free to link to mine) and telling why you prefer one over the other. Maybe my verbiage was not chosen well. I did not intend to insult. Rather I guess what I was saying is that the FE produces a very angled edge. No thats not right either. Yes, a picture really is worth a thousand words!
Jman13 Cream of the Crop 5,567 posts Likes: 164 Joined Dec 2005 Location: Columbus, OH More info | May 10, 2009 08:34 | #15 I use both ultra-wide and fisheye. they both have their places. Ultra-wide where you don't need the extreme width of a fisheye, and want straight lines preserved. Fisheye for absolutely insane width or areas where circles are involved (circles don't distort). Jordan Steele - http://www.jsteelephotos.com
| Latest registered member is Niagara Wedding Photographer 1333 guests, 109 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
