Had a go at HDR today,
Here is the result canal in Birmingham UK,
May 09, 2009 16:22 | #1 Had a go at HDR today, Nikon z9 + Nikon Z 24-120mm f4 S Lens + Nikon 500 F5.6 PF Lens
PKSmith Member 207 posts Joined Jan 2009 Location: Manhattan, Kansas More info | May 09, 2009 17:50 | #2 The sky sure is blown out for being an HDR image. You should try wider bracketing to bring the color back into the sky. | Rebel XSi | EF-s 18-55 f/3.5-5.6 IS | EF 50 f/1.4 | EF 70-200 f/4L | Speedlight 199A |
Gapton Member 75 posts Joined May 2009 More info | May 09, 2009 18:13 | #3 You are from Birmingham! Hahaha, I only looked your "location" after seeing this pic you took in Fiveways.
DerekSimon Senior Member 736 posts Joined Feb 2009 Location: Cleveland, OH More info | May 09, 2009 21:30 | #4 I agree with the lack of interest in this shot but for being a first HDR shot, I am more distracted by the lack of detail in the sky. HDR is meant to capture a range of colors that normally cannot be captured in just one shot. Definately bracket next run.
iamaelephant Senior Member 336 posts Joined Dec 2007 Location: New Zealand More info | May 10, 2009 02:46 | #5 Are you sure this is an HDR image? The dynamic range looks pretty natural, including the aforementioned blown out sky. -- Martin
Cathpah Goldmember 4,259 posts Likes: 5 Joined Jan 2006 Location: Maine. More info | May 10, 2009 14:25 | #6 I see nothing that makes me think this is an HDR photo. you sure you uploaded the right one? Successfully processed the shot? Architecture
May 10, 2009 16:11 | #7 Cathpah wrote in post #7893899 I see nothing that makes me think this is an HDR photo. you sure you uploaded the right one? Successfully processed the shot? you either need to re-process, or reshoot with the shots bracketed further out. Hi all, Thanks for the comments. Nikon z9 + Nikon Z 24-120mm f4 S Lens + Nikon 500 F5.6 PF Lens
BillBoehme Enjoy being spanked More info | The sky is very light, but not blown out. I can see blue sky and clouds and there is no clipping on the histogram. The image has a soft overall blur which is being caused by using a non-standard pixel aspect ratio. The image can be made much sharper by simply correcting the aspect ratio to 1:1. Non-standard pixel aspect ratios are normally only used for previews and otherwise should be set to unity. Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
beegeeboy Senior Member 304 posts Likes: 2 Joined Jan 2008 Location: In the middle of the UK... More info | May 12, 2009 16:09 | #10 It's difficult to get this right...you need to spend more time tone mapping in photomatix i think. The sky is better in this one though. Gear: A box with a hole; some tubes with glass in 'em
tonydee Goldmember 2,009 posts Joined Sep 2007 Location: Tokyo More info | May 12, 2009 16:35 | #11 Second attempt (post #9) is much better, but everything's blue. As beegeeboy says, just need to keep tweaking the settings. Every HDR package and algorithm is different, and results can vary from image-set to -set, so often it's a trial and error process. Cheers, Tony 5D and too much glass. Mamiya 645E.
Thanks for the input beegeeboy, Nikon z9 + Nikon Z 24-120mm f4 S Lens + Nikon 500 F5.6 PF Lens
| Latest registered member is semonsters 1031 guests, 113 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
