Thread started 12 May 2009 (Tuesday) 10:25
Use a car battery and inverter to power my monolights?
James33
May 12, 2009 10:25 |  #1
I have a couple of outdoor shoots coming up - dusk and later. I was thinking I could simply hook an inverter to my battery on the car and plug the monolight into it. Anyone do this? Any dangers? Using 150 watt second lights. Thanks!
James
www.jamesparkerphoto.c​om (external link)
jeromego
May 12, 2009 11:02 |  #2
you need to have pure sine wave power for use with strobes. i dont think doing that would give you pure sine wave.
Jerome
Canon CPS Member
www.lightsandimages.co​m (external link)
facebook (external link)
DozerLYP
May 12, 2009 11:03 |  #3
If the inverter can produce enough power to feed your light, it should just fine.
Home Improvement
Custom Brushes!
James33
May 12, 2009 11:21 |  #4
jeromego wrote in post #7906411 (external link)
"Pure sine wave power?" I have no idea what you are referring to... Any links to explain it in more detail?
Discov3ry
May 12, 2009 11:36 |  #5
James33 wrote in post #7906516 (external link)
Common inverters produce AC that has a square wave characteristic, pure sine wave power inverters produce a nice and smooth wave that flash units prefer.
This is my non-technical understanding of it after googling it up so maybe someone with an engineering background can chip in.
jeromego
May 12, 2009 11:37 |  #6
https://photography-on-the.net …&highlight=pure​+sine+wave
Jerome
Canon CPS Member
g-money
May 12, 2009 11:52 |  #7
You are converting DC voltage from a battery trying to make it run an item designed for AC. Invertors can give you three types of output
square wave which is the wave form DC voltage produces
modified sine wave, Which is a AC wave form but choppy, Usually found on the cheaper invertors. Will run many AC applications but would not trust it with anything with sensitive electronics.
Pure Sine Wave. This is what and actual AC circuit will put out. WIll cost more than many invertors, but should work Ok if it is large enough.
If they were my lights I would buy one of the invertors built for monolight like the Vagabond, but not sure they will work with anything other than AB lights.
Canon 6D X 2, Canon 5D, FUJI X100, Canon Rebel XT, Canon 24-70L VII, Canon 35L 1.4, Sigma 85mm f/1.4, Canon 70-200L 2.8 IS, Tokina 16-28 2.8, 580exII x2, Godox 850 X 2, 430ex
Website... [URL="http://www.gowen​sphotography.com"]Arkansas Wedding Photographerexternal link
Discov3ry
May 12, 2009 11:56 |  #8
g-money wrote in post #7906753 (external link)
Taken from AlienBees website http://www.alienbees.c​om/VIIsystem.html (external link)
"Operating Non Paul C. Buff, Inc. Flash Units:
The Vagabond II is designed specifically for powering Paul C. Buff, Inc. products and that we cannot make any claim for suitability with products from other manufacturers, nor can we accept any liability for any damage that might be caused to such equipment. We will, however, warranty the Vagabond II itself as well as any Paul C. Buff, Inc. equipment it powers.
So I guess it's all about warranty issues. As long as it's got a standard electrical outlet it should be good.
57hardtop
May 12, 2009 12:58 |  #9
Discov3ry wrote in post #7906779 (external link)
Standard Operating Procedure...never tell the consumer that your stuff is compatible with your competitors' stuff...scare them into buying your products only.
Roger
Gear list and feedback
http://retouching-on-the.net/forums/ (external link)
drh681
May 12, 2009 19:50 as a reply to  @ 57hardtop's post |  #10
did I just read thet the new AB line will operate on a modified sine wave inverter?
perhaps that is something that was applied to the vagabond unit in a manner that they KNOW works with AB.
5,002 views & 0 likes for this thread, 7 members have posted to it.
616 guests, 116 members online
