Hi,
I have a Nikons SB-15 and Toshiba A25L (which were like 1/10th the cost of the rechargeable batteries :P) which ive been using with a 7metre PC-sync (cut down from 10m, 10m was too long to fire it) for the A25L and SB-15 from on camera bounce fill.
Anyway, I recently ordered a Sunpak 433D (manual power settings
so it will be my new on camera main flash), 2xSunpak 433AF (one Nikon, one Minolta - which I can use pc-sync on and tape the contacts over if its one of the weird mounts, or do some soldering since it was $15), and a Vivitar one (3700 i think) all are GN120, swivel and bounce., the 3700 and 2x433AF's will be on stands or on floor and bounced, thus ND-gel'ing them isn't a huge inconvenience (especially since I get sheets of it for free).
I will be using these with my EOS 30D as well as my RB67 (for which I'll need a PC-sync terminal to hotshoe adapter for radio trigger since it only has pc-sync).
I dont want to spend a small fortune on triggers, so I'd be looking at ebay jobbies either the wireless stuff and 3 or 4 receivers, or 3 or 4 optical triggers.
I'm aware of the down falls of optical triggers outdoors and being fired by other people, in the future I may be in situations where I need radio (weddings, functions, etc).
So are the cheap radio triggers reliable for the job? and in the future for events as at least a stop-gap solution?
Or should I just go the optical triggers (probably cheaper), then when the time comes get better radio triggers?
