Thread started 14 May 2009 (Thursday) 10:38
Is Color calibration tool like spyder is a must?
danielyamseng
May 14, 2009 10:38 |  #1
How many of you guys use color calibration software like spyder pro/elite? Is it a neccesity? Or can have a workaround for it?
ChasP505
"brain damaged old guy"
May 14, 2009 11:23 |  #2
danielyamseng wrote in post #7920192 (external link)
It's hardware and software.
Is it a neccesity?
No... Only if you want an accurate color match between print and screen. Or you want your photos posted on the web to look the same as they looked on your system.
Chas P
gjl711
May 14, 2009 11:28 |  #3
It's not a necessity, but it is handy to insure that your display is representing the colors as they should be.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
EOS_JD
May 14, 2009 11:29 |  #4
ChasP505 wrote in post #7920434 (external link)
The Spyder Pro itself does not provide a match between print and screen. The spyder calibrates your monitor so that it shows colours correctly.
In order to achieve correct prints, you must also use a correct profile for your printer/ink/paper combination. the elite may come with the facility to provide these profiles but many paper manufacturers offer free custom profiles that are better and more accurate.
Is it necessary? If you take photography seriously YES. If a hobby - you can probably get by without it.
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
ChasP505
May 14, 2009 11:59 |  #5
EOS_JD wrote in post #7920480 (external link)
Spyder3 Elite standalone package is not a print calibration device and it doesn't produce printer profiles.
What if you take hobbys seriously? :rolleyes:
Chas P
ssracer
May 14, 2009 12:01 |  #6
I picked up a spyder 2 and it has made a world of difference.
- Sean
my gear
my flickr (external link)
tim
Light Bringer
May 14, 2009 16:52 |  #7
It's only important if you want your prints to accurately match your monitor. If you're not a professional I wouldn't worry too much, as you can always pay the lab a few dollars if you really need accurate color in your prints. I rely on my lab to do final color correction for my albums, mostly because it saves me time.
ChasP505
May 14, 2009 17:17 |  #8
tim wrote in post #7922417 (external link)
Wow! Twice in this brief thread I've heard this biased sentiment expressed. Why wouldn't a dedicated amateur or "hobbyist" photographer not want his/her prints to match or color to be accurate? So the amateur car mechanic doesn't need to get the ignition timing set right on his car because he's not a professional... he shouldn't worry too much. :(
Chas P
JackLiu
May 14, 2009 17:26 |  #9
Since I bought a Spyder2 and calibrated my monitor, it resulted in reduced waste from my inkjet printer ... which means lower cost per good print.
"Love life and life will love you back. Love people and they will love you back." Arthur Rubinstein.
John_B
Gallery: 178 photos
May 14, 2009 17:29 |  #10
danielyamseng,
No, for me it isn't needed. I have my monitor calibrated manually by a few tests with my cameras, scanners, monitors and printers. This is how it has been for years even for graphic designing. However I do believe calibration is a must if you want your photos either by print or displayed on your monitor to look the same.
click to see (external link)
danielyamseng
May 14, 2009 18:22 as a reply to  @ John_B's post |  #11
John_B , that mean there's an alternative get a similiar result without using color calibration tool? I think you really wasted quite a number of papers.
Any tips for manual calibration for both monitor and printer?
John_B
Gallery: 178 photos
May 14, 2009 18:56 |  #12
danielyamseng,
Not that much waste as it was much cheaper then an expensive thing to hang on my screen.
Here are some great links for calibration right here on POTN
calibrating monitor ?"s
Color problems?
Here are some external links:
Monitor calibration and gamma (external link)
The Macbeth Color Checker (external link)
The Lagom LCD monitor test pages (external link)
EOS_JD
May 14, 2009 19:14 |  #13
ChasP505 wrote in post #7922568 (external link)
Maybe because most hobbiests don't want to spend a huge amount of money on something that can be done at the lab.
But I get your point and if you take it seriously (pro or as a hobby) then get a decent hardware calibrator. THe Gretag MacBeth one gets rave reviews but the spyder does a very decent job.
If you want your prints to match, get the proper profiles for the printer/ink/paper that you use.
Monitor profiles for pc are icm files. Printer profiles are icc files.
All My Gear
Brad ­ Remick
May 14, 2009 19:18 |  #14
I just picked up a Spyder 2 and it seems to have really helped too.
Some stuff that says "Canon" on it and a happy trigger finger.
"You miss 100% of the shots you never take" Wayne Gretzky (Yes, I know he was talking about hockey but it seems applicable here too):) www.BradRemick.com (external link)
tim
Light Bringer
May 14, 2009 20:25 |  #15
Using software calibration you can get a "good enough" match that your prints will look good. Or pay the $0.50 that a lab charges for color correction if you have a few critical prints. Spending $300 and calibrating every three months isn't really necessary unless you have a need for precise color accuracy.
4,509 views & 0 likes for this thread, 14 members have posted to it.
1332 guests, 139 members online
