Just want to double-check and see if I'm understanding this correctly...
I have a couple alien bees and use cyber sync's to trigger them. I'm comfortable with them, and use them for inside studio-type shots... I shoot in manual with 1/200 shutter speed due to sync-speed limitations.
For "travelling flash" I have a 430EX, which I keep in high speed sync mode all the time, since it only uses it when needed.
I want/need to do more shots in bright sunlight at fast aperatures (<2.8), which means fast shutter speeds and mandatory HSS on the flashes to fight the sun.
Are these my only options:
1) Get a 580EX or ST-E2, connected to my camera's hot-shoe, set as master, and trigger my off-camera 430 as a slave. I've read these don't work well in bright sunlight though.
2) Get a 580EX and connect it to the camera with a long ETTL cable. Would still have the same problems triggering the "slave" 430 in bright sunlight, but would benefit with being able to have both flashes off-camera. Negative side is it's not wireless.
3) Get Radio Poppers or the new Pocketwizards which support ETTL and high speed sync.
Those are my only options (essentially), right? High speed sync only works with ETTL and Canon Speedlites? There's no way to get my alien bees or any strobes to high speed sync, right?
Thanks in advance for your help...
