Sounds like a basic question, but I'm wondering what portrait photographers are usually using.
I'm assuming f/2.8 at the widest with most shots being done at f/5.6 or maybe f/8 to f/11 for groups.
Yes? No?
n1as Goldmember 2,330 posts Likes: 25 Joined Oct 2007 Location: Salem, OR More info | May 15, 2009 11:40 | #1 Sounds like a basic question, but I'm wondering what portrait photographers are usually using. - Keith
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | May 15, 2009 11:47 | #2 Depends of what you want to acheive. Do you want a blurred background? Are you in a studio? Are you in front of some stunning background scenery? You could use any aperture, really. Taylor
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | May 15, 2009 11:47 | #3 Depends on what lens you are using, what body and mostly your background. In general, the fastest f/stop you have is good for a head shot but sometimes difficult to pull off. Good portraits can be done at any aperture actually. Just don't have too many telephone poles coming out of their heads. GEAR LIST
KenjiS "Holy crap its long!" More info | What he said it depends Gear, New and Old! RAW Club Member
jerokaz Senior Member 897 posts Joined Sep 2007 Location: Salinas, CA More info | May 15, 2009 11:59 | #5 If you are shooting in the studio with a backdrop, you would probably use a smaller aperture for subject sharpness, assuming you have plenty of light or have control of the light. For outdoor portraits, I'd think you would want a larger aperture, because you have less control of the light, and there would be more distractions in the background so you want more background blur and subject separation. www.rmbphoto.net
Rodinal Goldmember 1,127 posts Joined Jul 2008 More info | May 15, 2009 12:04 | #6 Permanent bann1as wrote in post #7927135 Sounds like a basic question, but I'm wondering what portrait photographers are usually using. I'm assuming f/2.8 at the widest with most shots being done at f/5.6 or maybe f/8 to f/11 for groups. Yes? No?
1D Mark II • 16-35/2.8L mk I • 24-70L • 70-200/2.8L IS • 50/1.8 • 24-85 • 400/5.6L • 430EX
Rodinal Goldmember 1,127 posts Joined Jul 2008 More info | May 15, 2009 12:11 | #7 Permanent banMy simple rule for sharpness in portraits: 1D Mark II • 16-35/2.8L mk I • 24-70L • 70-200/2.8L IS • 50/1.8 • 24-85 • 400/5.6L • 430EX
joemama Senior Member 666 posts Joined Oct 2005 Location: Earth More info | May 15, 2009 12:11 | #8 Permanent bann1as wrote in post #7927135 Sounds like a basic question, but I'm wondering what portrait photographers are usually using. I'm assuming f/2.8 at the widest with most shots being done at f/5.6 or maybe f/8 to f/11 for groups. Yes? No? Depends. However, I often shoot at apertures wider than f/2.8: Canon 5D + 100 / 2 @ f/2, 1/320, ISO 400 http://www.pbase.com/joemama/image/108079404 Canon 5D + 100 / 2 @ f / 2, 1/250, ISO 100 http://www.pbase.com/joemama/image/86186745 Canon 5D + 50 / 1.2L @ f / 1.2, 1/250, ISO 100 http://www.pbase.com/joemama/image/95757482 Canon 5D + 50 / 1.2L @ f / 1.2, 1/50, ISO 1600 http://www.pbase.com/joemama/image/80379021 --joe
May 15, 2009 15:30 | #9 Like they said, depends on what you are trying to achieve.
May 15, 2009 20:31 | #10 OK, so I guess the answers are all over the map. LOL! I should have known better. - Keith
gooble Goldmember 3,149 posts Likes: 1 Joined Jul 2006 Location: Mesa,AZ More info | May 15, 2009 20:41 | #11 n1as wrote in post #7929915 OK, so I guess the answers are all over the map. LOL! I should have known better. I'm specifically thinking of senior portraits and wedding portraits. Bread & butter shots, stuff that sells to Moms & Dads. For that reason, I tend to lean away from the wide open shallow DOF style, but Joe Mama's pics (above) sure make me pause and rethink it all. Yep.
nightcat Goldmember 4,533 posts Likes: 28 Joined Aug 2008 More info | May 15, 2009 20:41 | #12 Joe Mama's portraits are among the best I've seen. I notice he uses the 100mm 2.0 which is a beautiful portrait lens. I also like shooting wide open, but lately I've started stopping down a little to assure I'm getting the subjects face in focus. Sometimes when I'm using a fast prime wide open, its hit or miss.
xander2188 Member 93 posts Joined Jun 2006 More info | May 15, 2009 20:42 | #13 Rodinal wrote in post #7927297 The central factor in blur and bokeh-related questions is distance that separates your subject from the background. The shortest it is, the faster your lens needs to be in order to achieve blur. In a small bathroom, I have obtained blurry background at f/2.0 using a 50/1.8, and I got the same kind of blur outdoors, using a 70-200/4 below 100mm, at f/4. In the first example, walls were 4 ft behind my subject and in the 2nd example, a fence and a tree (which came out blurry at f/4) were about 20 ft behind. Blur was basically the same in both cases. So, there's no rule really. 5.6 and 8 can give you the same amount of blur if what you're trying to blur out is far far away. There are three things that affect bokeh, aperture, distances between the camera the foreground and the background, and focal length of the lens you are using.
Rubberhead Goldmember 1,899 posts Likes: 1 Joined Feb 2006 Location: South Carolina's Lowcountry More info | May 15, 2009 20:46 | #14 Joe Mama - great stuff; my hats off to you... EQUIPMENT: 40D | Rebel XT | EF 70-200mm f/4L IS | EF-S 10-22mm | EF 28-135mm IS | EF-S 18-55mm IS | EF 50mm 1.8 - flickr
joemama Senior Member 666 posts Joined Oct 2005 Location: Earth More info | May 15, 2009 23:56 | #15 Permanent bann1as wrote: OK, so I guess the answers are all over the map. LOL! I should have known better. I'm specifically thinking of senior portraits and wedding portraits. Bread & butter shots, stuff that sells to Moms & Dads. For that reason, I tend to lean away from the wide open shallow DOF style, but Joe Mama's pics (above) sure make me pause and rethink it all.
Note that wide open is effective because the framing is not very tight and the couple lies on the focal plane. This pic, on the other hand: Canon 5D + 50 / 1.2L @ f / 5.6, 1/160, ISO 50 http://www.pbase.com/joemama/image/81894023 uses a smaller aperture since I was closer to the subject and framing more widely. In addition, the people are stacked deep, so a deeper DOF is needed to accommodate them. On the other hand, the people in this pic are more closely aligned to the focal plane: Canon 5D + 50mm / 1.4 @ f / 2.8, 1/13, ISO 800 http://www.pbase.com/joemama/image/54018002 so a wider aperture could safely be used. So, in terms of DOF, you could take group shots at f/1.2 if everyone were along the focal plane and you framed widely enough (although edge softness and vignetting would likely still make it an iffy proposition for such an image), whereas other times you might need f/11 or f/16 to hit your mark. In other words, there is no "optimal" f-ratio -- just an "appropriate" DOF. And an "appropriate" DOF depends on more than just the aperture. nightcat wrote: Joe Mama's portraits are among the best I've seen. I notice he uses the 100mm 2.0 which is a beautiful portrait lens. I also like shooting wide open, but lately I've started stopping down a little to assure I'm getting the subjects face in focus. Sometimes when I'm using a fast prime wide open, its hit or miss.
Rubberhead wrote: Joe Mama - great stuff; my hats off to you... Thank you kindly! I envy that you can take your hat off to me -- everyone tells me to keep mine on! : ) --joe
| Latest registered member is semonsters 1505 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
