Thread started 17 May 2009 (Sunday) 14:39
Perspective Correction Tips
The ­ Ghost ­ of ­ FM
May 17, 2009 14:39 |  #1
I took this picture with my trusty 17-40L lens at the wide end and fairly close to the building in order to get the whole church into the frame and avoid getting all the ugly power and telephone poles and wires into the shot.
The problem now is that the Church came out badly warped and I have tried my best with Photoshop Elements and another program, Microsoft Digital Image Pro 2006 to remove/correct distortion and just can't seem to come up with something that looks as natural as if I would have shot this with a longer focal length from a greater distance away.
Here's the picture;
IMAGE: http://i66.photobucket.com/albums/h250/thefontmeister/VV4G1477small.jpg
What I was hoping was that someone out there with more perspective correction "kung fu" could take a stab at straightening this and briefly documenting how they did it. I know I have image editing permission turned off but in this particular case, please feel free to download this picture and post your result at attempting to straighten it out.
Cheers!
GEAR LIST l WEBSITE (external link)
BroX
May 17, 2009 14:59 |  #2
Using The Gimp I stretched the perspective along the top wider to left and right, then pulled the right top corner down a bit. Rotated a few degrees anti-clockwise to straighten the horizon, and then reduced the width of the whole image until it seemed to correspond with your original image of the church. Nothing special really... but maybe this not at all what you were looking for? My 2cents.
40D · 11-16mm f/2.8 · 17-50mm f/2.8 · 70-200mm f/2.8L IS II · 430EX II · 055XPROB/488RC2
Christopher ­ Steven ­ b
May 17, 2009 15:09 |  #3
Here is my 2 minute attempt. used the crop tool in PS with 'perspective' checked--placed crop where black lines are in upper image.
christopher steven b. - Ottawa Wedding Photographer
www.christopherstevenb​.com (external link)| Blog (external link)
May 17, 2009 15:31 |  #4
Christopher Steven b wrote in post #7938440 (external link)
Wow! :)
That looks great!
I wonder if I have the "perspective" check box in the crop tool of Photoshop Elements?? I hope so!
Thanks so much for the tip!
Cheers!
May 17, 2009 16:38 |  #5
The Ghost of FM wrote in post #7938505 (external link)
Wow! :)
That looks great!
Cheers!
It turns out I don't have that functionality in in PS Elements! :confused:
I did find a "free transform option though in the Image/Transform/free Transform which brought up a new tool bar with rotation, re-sizings and screwing the image...it's a bit more basic I guess then what PS is offering in that you can't just draw lines, like posted above. You have to instead pull and push the corners to get it to do what you want it to but I guess in the end, achieves the same thing.
Thanks again for the help here!
Cheers!
Peano
May 17, 2009 17:17 |  #6
This one takes some pretty radical stretching. Here's one way it can be done in Elements:
  1. Duplicate the image onto a new layer.
  2. Expand the canvas at least 25 percent on top and both sides.
  3. Ctrl-click the copied layer to select it.
  4. Hit Ctrl-T to get a transform bounding box around the image.
  5. Hold the control key and adjust the top corner handles. Pull them out toward the side to correct the tilt on that side. Pull the other top corner to correct tilt on that side. You can also pull those corners up or down to correct horizontal tilt.
When you finish vertical lines upright, you'll need to grab the top center handle and stretch the image vertically. All that horizontal pulling squashes the image down, so you need to stretch it vertically to correct for that.
IMAGE: http://img194.imageshack.us/img194/3509/perspective2.jpg
Peano
RadiantPics.com (external link)
May 17, 2009 17:38 as a reply to  @ Peano's post |  #7
Peano,
That's not too bad it still looks like the church is on a slope and in reality, the ground was very level.
I do appreciate the tips though and I'm working my way through them, trying to play with features in PSE that I've never touched before.
Cheers!
Peano
May 17, 2009 18:06 |  #8
The Ghost of FM wrote in post #7939105 (external link)
Peano,
You can Ctrl-drag the corner handles to stretch the bottom left corner down and make the base of the church level. But note what will happen: That will stretch the windows on that end, and they'll be larger than the ones on the right.
Peano
May 17, 2009 19:09 as a reply to  @ Peano's post |  #9
I've been messing around with it for the past couple hours and think I finally pulled it into the shape I envisioned it should look like and also polished it up a bit with some further tonal enhancements.
How does it look to you folks now?
IMAGE: http://i66.photobucket.com/albums/h250/thefontmeister/VV4G1477copysmall.jpg
Thanks again for everyone's help on this!
Cheers!
Maxdave
Gallery: 49 photos
May 18, 2009 06:34 as a reply to  @ The Ghost of FM's post |  #10
You may want to download and try ShiftN, which does a pretty good job of automatically correcting some images:
http://www.marcus-hebel.de/index1.html (external link)
Mr. Hebel is the program developer/writer and the program is Freeware.
I have used it successfully several times for subjects like your church ....
Maxdave
5D3,1D4,S90,6S&Moment Lenses,Hero4Silver,GPS​-E2,2x580EX,430EX,90EX,​EF16-35L f/4 IS,Samy SYTS24-C 24TS,EF24-105L IS,EF50 f/1.4,EF70-200 f/4L IS,EF300 f/4L IS,EF100-400L I IS,Kenko DGX 1.4X,Canon 2X TC Mk II, RRS&Pro-Media L-Brackets,Manfrotto MHXPRO-3WG & Roller 50,Sirui 306&K-20,Giottos MT-7371&MH-3300,Velbon ElCarmagne 530,CamRanger,Phottix&​Canon Remotes,Lowepro Backpack,ThinkTank Retro 20&Modular System,OpTech straps,Lexar/San Disk Cards
May 18, 2009 07:33 |  #11
Maxdave wrote in post #7942134 (external link)
Maxdave
Thanks for the link! ;)
I downloaded and tried the program out but it didn't really do a stellar job on this particular file. Perhaps it works better on images with less distortion then this particular one?
Cheers!
Wilt
May 21, 2009 17:30 |  #12
Here is the corrected photo after processing with Paint Shop Pro...
1,783 views & 0 likes for this thread, 6 members have posted to it.
1014 guests, 107 members online
