Thread started 23 Apr 2005 (Saturday) 17:04
whats the difference
monkey_wrench
Apr 23, 2005 17:04 |  #1
between formatting your memory card and erasing the images?
:confused:
Canon 5D - Canon 30D - 12-24mm Sigma - 24-105mm Canon L - 18-200mm Sigma - 2x 580ex flash guns
am_pitbull_terrier
Apr 23, 2005 17:14 |  #2
You should always format the card on occasion. Erasing images may leave corruption that could build up. Formatting will get rid of this. This will keep you at maximum capacity on your card
I think:D
Powershot G3
LA-DC58B Lens Adaptor
Spot Filter 58mm
Diffusion Filter 58mm
SkyLight Filter 58 mm
SuperWide Lens
Rebel XT (black), 18-55mm, 24-70mm 2.8, 70-300mm /Lens Hood, 50mm 1.8
Opteka Grip
Radio Slave Trigger
Stroboframe Flash Bracket
580EX Flash & Canon Off Shoe Cord 2
Lumiquest On-Camera Softbox
And of course a POTN camera strap :)
monkey_wrench
Apr 23, 2005 17:29 as a reply to  @ am_pitbull_terrier's post |  #3
I think:D
but i have been formatting my card everytime i need to erase images because it is alot quicker could that reduce the amount of images the card can store because its gone from 120ish to 77 in Large Super fine :confused:
am_pitbull_terrier
Apr 23, 2005 17:36 |  #4
That I'm not sure of. I never heard of anything like that. I just format about once every month or 2 and my card seems to be holding the same as it always did. I didn't know you formatted every time. I thought you were saying you never format.
Powershot G3
Spot Filter 58mm
SuperWide Lens
Opteka Grip
Radio Slave Trigger
monkey_wrench
Apr 23, 2005 17:50 as a reply to  @ am_pitbull_terrier's post |  #5
no i always format haha never erase, takes longer :confused: hmmm im lost now
txfirebug
Apr 23, 2005 18:57 as a reply to  @ monkey_wrench's post |  #6
This doesn't address the specific subject of formatting often but did provide for some interesting CF reading.
http://www.robgalbrait​h.com/bins/multi_page.​asp?cid=6007 (external link)
sixshot
Apr 23, 2005 22:15 |  #7
Formatting shouldn't reduce the memory of the card. Not sure why that would happen.
20D | 17-40mm L | Patience
Ben
mdm
Apr 23, 2005 22:21 |  #8
I thought it was like a computer, you don't format unless you have a problem.
Skip ­ Souza
Location: The Left Coast in the Land of Fruits and Nuts
Apr 24, 2005 00:26 |  #9
I always format. It is especially useful if you use the same card in different cameras.
Deleteing just removes the marker so that the info can't be found. Eventually it will be overwritten because the camera/computer can't see that there was info there.
Formating overwrites the whole card and reorders it into into the tipe of file sustem used e.g. FAT 16, FAT32, QFA, or whatever. By formating it prepares it for use in your camera. Handy in case you have different types/brands/ages of cameras.
You should not lose capacity by formating.
Bless the recently fallen and their family and friends.
I have a Cannon with me at all times. You can't take the shot if you don't have something with which to shoot. :rolleyes:
That which does not kill me ~~ Should Run.
5DMkII, 7D, 70-300L IS, 24-105L,
No more PayPal gift payment requests.
"PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED."
LadyHawk
Apr 24, 2005 00:34 |  #10
I alway just format the card. And I read somewhere in a digital photography type book that there is no problem with this at all.
Karen
_______________www.ctw​ebworx.com
merv
Apr 24, 2005 02:54 as a reply to  @ LadyHawk's post |  #11
i experience the same prob too.. lost 1mb memory after formatting my 1gb high speed CF card... is there some problem with it??
Skip ­ Souza
Apr 24, 2005 03:43 |  #12
Are you saying that your 1mb card went to 0mb?
Skip ­ Souza
Apr 24, 2005 03:43 |  #13
Sounds like a bad card to me.
Skip ­ Souza
Apr 24, 2005 04:29 |  #14
I miss read your post. When you format a card a small amount is used for the file system formatting. You only lost one tenth of one percent of the card. No big deal
gkuenning
Joined Jan 2005
Apr 24, 2005 09:40 |  #15
Wow, I can see that there's a lot of misinformation floating around.
I'm somewhat embarrassed by my own lack of ability to give a definitive answer, since filesystems are my specialty. Unfortunately, camera manufacturers don't tend to publish papers about the fine details of how their firmware works, so I'll have to stick to generalities.
I think part of the confusion comes from the fact that "formatting" used to have different meanings when applied to older hard drives. This probably led to am_pitbull_terrier's misunderstanding that formatting can clean up corruption. On the G series, it definitely can't. (Nor can it do so on microdrives or other hard drives; they're formatted at the factory. An easy clue is the speed: formatting to resolve corruption takes at least as long as filling the card with pictures copied from another camera.)
With one caveat (see below) the practical difference between formatting and using "erase all" is twofold: (1) formatting is much faster if you have more than a couple of images, and (2) formatting won't respect the "protect image" setting; it'll erase everything even if you've set image protection. So my recommendation is to use full format if you're in a hurry and "erase all" if you use the image-locking feature.
The caveat I mentioned is that any particular location in flash memory has a limited number of times that it can be written. It's possible (actually, fairly likely) that formatting will cause the card to become unusable more quickly, because formatting requires rewriting the same location every time, whereas erasing give the camera a bit more flexibility so that it can "even out" the memory locations it uses. However, the "limited number" is always at least 10,000. So if you format your card 10,000 times it might wear out sooner than if you used "erase all" 10,000 times. (grin) Personally, I expect to replace my CF card with a bigger one long before I hit the 10K limit, so I don't stress out about it.
If you want more gory details, private-message me.
Geoff
All I want is a 10-2000 f/0.5L with no distortion that weighs 100 grams, fits in my pocket, and costs $300. Is that too much to ask?
3,730 views & 0 likes for this thread, 11 members have posted to it.
2527 guests, 97 members online
