Hello All,
Could someone take a look at the four photos located at http://www.pbase.com/mlfrancis/g2questionshots
and fill me in as to what is happeninig?
Here is the deal. First, these shots are not of anything expect my light fixture. I was playing around with my 420ex flash on my G2 and came up with a set of shots that when just pressing the shutter does not yield the same result as doing a flash/exposure lock.
It all started because I was playing around with the Av to see what kind of fill flash effect I could get. I put the camera in spot exposure and put the "spot" on one of the light bulbs. Now when I shoot this by just pressing half-way, then recenter the lights, then pressing the rest of the way, I get what looks like a shot with the flash fireing in full power. Now, if I spot the light bulb, then press * (flash/exposure lock), recenter, then I get a shot that looks like the flash actually fired in fill flash mode.
I get the same whether in P or Av. That suprised me as well. I expected to get the "full power" look from both when in P, but I didn't expect to get it at all in Av.
Anyone have any idea why I am getting two different exposures when the only difference is I am using the flash/exposure lock in one?
The shots are:
63 - P half press/recenter, then press
64 - P flash/exposure lock, recenter, then press
65 - Av half press/recenter, then press
66 - Av flash/exposure lock, recenter, then press.
By the way, P gave me an exposure of 1/250 at F4 both times. Then Av I set to F4 to match - sure enough it worked it out to 1/250 each time.
Any help would be appreciated.
