FORUMS Marketplace & Market Info Market Watch
Thread started 18 May 2009 (Monday) 15:58
Dry Mount Press, worth it?
SteveNC
May 18, 2009 15:58 |  #1
A local business owner offered me a dry mount press for $200 OBO. Goes up to 16" x 20." He said he's had it in storage for 15 years and that it's only been used one time. This person seems trustworthy though I have never met him.
I'm not up on my dry mounting equipment. :) What would a fair price for such equipment be? He's asking $200 OBO for it. Could be useful for cutting costs on matting and framing my own prints, though I really don't know how to do it. I could always learn...
Any thoughts?
"Dream it. Plan it. Do it."
- National Geographic ...with a 300D and a kit lens (external link)
85 1.2L II, 70-200 2.8L IS, 100-400L IS, 17-40L, 50 1.4, 85 1.8, Elinchrom, Lastolite, Photoflex, Think Tank, Member: Canon Professional Services, National Association of Photoshop Professionals
ed ­ rader
"I am not the final word"
May 18, 2009 16:51 |  #2
SteveNC wrote in post #7945107 (external link)
Any thoughts?
i dunno. dry mounting doesn't cost that much....maybe $20 for a 16" 20" print (20" x 24" actual)?
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
703ohio
May 19, 2009 11:14 as a reply to  @ ed rader's post |  #3
I would ask him to do a few tests with it
Go to any craft store buy some board and drymount tissue-
use a photo that is not sacred and mount a few up
what to watch out for or typically goes wrong?
temp gauge does not work- avoid the thing
temp gauge is off - no problem just do a slight adjustment
check the hinge mechanism - they are famous for failing- will impact the pressure on the paper and to some extent the temps
is his price fair? yes it is if you do a lot of drymounting
I have one that is at least 30 years old- works great
hope that help a little
Jim
mobileman
May 19, 2009 17:37 |  #4
Its hard to believe that a person would buy and setup a drymount machine and only use it once, but I guess stranger things have happened. I've had a drymount machine for over 20 year. It has saved me a fortune in mounting prints compared to having it done.
Its a larger machine than the one your looking at and it cost me $1,800.00 new. You should look this machine over good. Take your hand and rub it over the top of the inside of the machine to insure its smooth. If not it might only need a cleaning, but if its only been used once it should be very smooth. If its not smooth it will cause indentions in your photo. Plug it in set the tempature and make sure it heats up to the setting.
If these things check out ok go for it the price seems good! Also does it have its mat that fits on the inside of the bottom of the machine.
Good luck
SteveNC
May 19, 2009 19:36 |  #5
Thanks guys, I appreciate it. I emailed the person with the questions advised and will report back.
SteveNC
May 19, 2009 21:17 |  #6
Does the temperature gauge function correctly?
Is the hinge mechanism working correctly (applies even pressure on the paper)?
Are the surfaces smooth?
does it have the mat that fits on the inside of the bottom of the machine?
As far as I know everything is working properly. I had one other offer from last night but the gentleman won't be able to get back to me until thursday. The press is at the intersection of XXX Ave. and XXXX Rd. in XXXX [In storage]. If you would like to swing by and take a look at it just let me know and we'll definitely work something out.
SteveNC
Jun 01, 2009 12:55 |  #7
So I ended up purchasing the press. I think it's a pretty good deal at $200 considering the same model today goes for $1351 shipped from B&H: http://www.bhphotovide​o.com …ry_Mounting.htm​l#features (external link)
I really appreciate the help with this purchase. I'll post some photos once I get it. Does anyone know of good resources for teaching oneself about mounting?
678 views & 0 likes for this thread, 4 members have posted to it.
2464 guests, 121 members online
