eaglesnest wrote in post #7947014
I wonder why my birds images aren't sharp ? I attached 2 of the better shots I have.
*Yellow bird : 1/1000 sec,f 13, Tv,AI servo,Centre point, ISO 800,400 mm
* Black bird : 1/800 sec,f 7.1,Tv,AI servo,Centre point, ISO 640,400 mm
Should I use a monopod instead of handheld?
Is the subject too far?
Need some tips and advice.
Thank you
At 1/1000 or 1/800 you shouldn't have shake problems, however I wouldn't go much slower than that without some sort of support.
At f13 you loose in sharpness, but not too much. You should be able to see it only at 100% crop, and then in optimal conditions. I usually keep between f5.6 and f11.
What could be a problem is AI Servo: if you're only shooting standing birds, use One Shot, if you're mainly shooting standing birds with some flying shots between them, use AI Focus: it sometimes behave unexpectedly and you have to get to know it's behaviour, but once you've done that, it's ok. Use AI Servo only if you're shooting only flying birds: on a standing object on AI Servo, the autofocus will keep hunting because your handhold is not perfectly still, or simply because within the center point cross lines it identifies different focusing planes, therefore you're never sure of the results.
I sometimes use a monopod, but then only when I am out for the whole day shooting, and I would get too tired otherwise
I usually shoot in manual mode, or in AV is I have quickly changing conditions (i.e. scattered clouds) and keep an eye on the aperture time: I try to keep it shorter than 1/640, but I also got good shots at 1/250 (low yeld, though). When light fades, I first open the lens up to f5.6, and only then if needed step up the ISO: the loss of sharpness at f5.6 from f8 (the optimal for this lens) is way less than having the ISO doubled.
Another trick: if you're afraid of shaking the shot, try shooting in high speed drive, taking 2 or 3 shots at a time: usually the 2nd and 3rd shots are much more steadier than the 1st.
In summary, keep your ISO lower, open you lenses, use One Shot autofocus and take short bursts of pictures at a time.
Hope will help!
