Thread started 19 May 2009 (Tuesday) 09:11
Making Dull photos Un-Dull!
Nevtiger
May 19, 2009 09:11 |  #1
Gents,
Are there any simple tips in making dull photos - due to overcast weather - a bit more bright and colourful?
I went to Brussels this weekend with the wife and when ever we have been any where we always pick a few of the best photos for the hall wall.
However, it was very overcast/raining and my images from my 20D are very flat and i wondered the best way to 'Boost' them.
I have shot everything in RAW as well as JPEG as i knew one day i would start trying to play with the images!
I have PS Elements 5.0 and GIMP here at home but am not sure where to start :oops:
Nev
70D + 18-135mm
Stolen (But not forgotten): Canon 50D and Tamron 17-50mm 2.8.
Given to Daughter: Canon 55 - 250mm
In Bag: Canon 100-400L
In2Photos
May 19, 2009 09:37 |  #2
Post an example and let folks have a play with it, telling you what they did to their edit. Then you can take the advice and get something you are happy with.
Current Gear and Feedback
Nevtiger
May 19, 2009 09:48 |  #3
How do i post a RAW file to the thread?
I can see how i would do it with a JPEG as i use Photobucket but can't seem to see how to get the RAW up?
Nev
70D + 18-135mm
tonylong
...winded
Gallery: 60 photos
May 19, 2009 10:09 |  #4
You can't post the RAW file -- it has to be converted to a jpeg first. Take your "as shot" file, either the jpeg or convert the RAW to a jpeg, resized for the Web, and post it here.
For some examples of RAW conversions that deal with these issues, check out the RAW Conversion thread:
https://photography-on-the.net/forum/showthre​ad.php?t=684360
Tony
Nevtiger
May 19, 2009 10:42 as a reply to  @ tonylong's post |  #5
Tonylong, thanks for posting your thread i shall have a good look through it see if i can't get an idea for what iu am trying to achieve.
Cheers
Nev
70D + 18-135mm
sparker1
May 19, 2009 14:49 |  #6
You might try Local Contrast Enhancement, http://www.luminous-landscape.com …ontrast-enhancement.shtml (external link). I've done it very little, but it can help overcome those overcast situations.
KarlosDaJackal
May 19, 2009 16:09 as a reply to  @ sparker1's post |  #7
Easy, open jpeg in gimp, hit colors >> levels. press the auto button and ok. That should be it.
Picture is no longer dull, if that works for you then you can implement the same thing at the raw stage in dpp by grabbing the edges in the histogram window and pulling them inwards to meet the edges of the picture data. The more you move the left in the blacker the blacks get, the more you move the right in the whiter the whites get. By stretching out the contrast you should get rid of any kind of dull gray cast to the pictures.
My Website (external link) - Flick (external link)r (external link) - Model Mayhem (external link) - Folio32 (external link)
Gimp Tutorials by me on POTN
Ziffle
May 19, 2009 16:17 |  #8
Nevtiger,
You could also link back to your photo bucket site w/ full res jpegs some of us could play w/.
Each individual could then download the images off your site.
Later,
_Mark
Wedding Photog's rule ........... just not sure what???
Gear List ~ VIAweddingPhoto(DOT)co​m (external link)
tim
Light Bringer
May 19, 2009 17:24 |  #9
Add contrast, saturation, and brightness.
sorpa
Gallery: 27 photos
May 19, 2009 19:33 |  #10
For a rainy/overcast day I'll go B&W.
Peano
May 19, 2009 20:12 |  #11
Nevtiger wrote in post #7949744 (external link)
You can upload it to www.yousendit.com (external link) and post the link here.
Peano
RadiantPics.com (external link)
xn2b8r
May 20, 2009 02:02 |  #12
Peano wrote in post #7953234 (external link)
Yousendit.com files are available only for a limited time (a week, I think) and a limited number of downloads. Great for sending, but not great for a forum that encourages searching existing threads. It's frustrating to spend time searching a topic only to find dead links.
--Jeff
1D Mark III :: 5D Classic w/BG-E4 :: EF 24-70 f/2.8L :: EF 135 f/2L :: EF-S 17-55 f/2.8 IS :: EF 70-200 f/2.8L IS II :: 580EX II (x4) :: ST-E2 :: Gitzo GT2330, GT1541T :: Markins M10 :: Feisol CF mono
Nevtiger
May 20, 2009 03:51 as a reply to  @ xn2b8r's post |  #13
Ok, here is a shot in Brussels.
I have converted it to jpeg without any adjustments via UFORAW for GIMP. I tried with Elements but it would not convert to jpeg that Photobucket could see it was a jpf or something!
http://i253.photobucke​t.com …PEGnoadjustment​UFORaw.jpg (external link)
I have tried playing with the Histogram as Karlosdajackel suggested but in the RAW converters i cant seem to move the histogram in either UFORAW or the one in Elements. I do have a curve thing in UFORAW that i can play with which is a straight line that can be bent! I can also move the histogram about if i then open a converted image in GIMP once its been through UFORAW.
As i understand it from lots of reading of threads last night that its better to do this sort of thing at the RAW conversion stage - DPP is it??
Nev
70D + 18-135mm
FstopMiami123
Gallery: 144 photos
May 20, 2009 07:00 as a reply to  @ Nevtiger's post |  #14
Here is the original along with a couple of edits
They might or might not be to your liking as the pp tends to be very subjective.
Adjusted curves,vibrance and did some sharpening tweaking
Canon 5DSr Canon 5D MK4 Canon 5D MK2 17-40 L 16-35 2.8 L Canon 70-200 2.8 IS L Canon 300 2.8 Canon 600mm 4.0 IS LCanon 50mm 1.2 Canon 85mm 1.8Canon 600EX
www.CollsFineArtPhotog​raphy.com (external link)
Nevtiger
May 20, 2009 08:45 |  #15
FstopMiami123 wrote in post #7955669 (external link)
Nice one thanks!
Now you say you adjusted the 'curves' is that the straight line on a graph that i can 'wobble' about?
I can not vibrance on my Elements or UFRaw/GIMP but i can see what you have done - i think with playing around.
Nev
70D + 18-135mm
4,454 views & 0 likes for this thread, 13 members have posted to it.
Latest registered member is vinceisvisual
1182 guests, 171 members online
