Thread started 20 May 2009 (Wednesday) 21:50
Vector Fil in PS?
30D'er
May 20, 2009 21:50 |  #1
Hope this question is not misplaced, but does anyone know...if i were to buy a vector file from istock, would i be able to open and edit it in PS3?
Gear
5D w/Grip, 30D w/grip, 24-70mm 2.8/f L, 70-200MM 2.8, L, 85MM 1.8/f, 50MM 1.8/f, 50MM 1.4/f,
580EX x 2, 580EX II, ST-E2, PIXMA PRO9500
ThinkTank 40, Airport Airstream & Belt System, Custom Bracket, and more!
Hikin ­ Mike
Walkin' Like a Penguin Now!
Gallery: 16 photos
May 20, 2009 23:38 |  #2
No. I have Illustrator 10 and CS2, so I just checked. You can see the vector file (.ai), but CS2 converts it into a PDF, so no you can't edit it. I'm sure it's the same thing using CS3.
Images in the Backcountry (external link)
Canon 5D 17-40 Ճ/4L 300 Ճ/4L IS 70-200 Ճ/4L 50 Ճ/1.8 1.4x TC Օ Kenko Ext. Tubes
Damo77
May 21, 2009 02:26 |  #3
Yes, you can edit it, but only as a raster file, as far as I'm aware. It will no longer be in vector format. So, you'll be losing some of the benefits of a vector file, but that may not be a problem for you. If, for example, you are preparing artwork for your website, then it will need to end up in pixel form anyway.
Damien
Website (external link) | Facebook (external link)
René ­ Damkot
May 21, 2009 02:32 |  #4
You can import a vector file as a shape layer AFAIK...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
30D'er
May 21, 2009 09:30 |  #5
hmmm...so how about opening a new file, setting the resolution to like 300 or 1000dpi, then importing the file. I really just need to trace the outline.
Gear
Damo77
May 21, 2009 16:19 |  #6
Well, in that case, just open it (and set the resolution in the rasterize options). It should come in on a transparent background, then you can simply Ctrl-click on the layer (in the layers palette) to automatically select the shape.
Damien
30D'er
May 22, 2009 20:45 |  #7
Think it may be worth a shot. Thanks for the input folks....
Damo77 wrote in post #7965102 (external link)
Gear
silvershoes
May 23, 2009 17:32 |  #8
You can also use the place command. It should work fine for what you want.
1,157 views & 0 likes for this thread, 5 members have posted to it.
Vector Fil in PS?
1089 guests, 178 members online
