Thread started 21 May 2009 (Thursday) 09:23
50D using Lensalign Question????????
TheFloridaShooter
May 21, 2009 09:23 |  #1
I'm hoping for a quick answer.
When you calibrate a 50D using a LenAlign at what distance do you set between the LensAlign and a EF-S 10-22mm and a 70-200mm ?
I’d really like the distance in feet.
1Dx MKII | 1Dx | 5D MKIV | 5D MKIII | 5Ds r | 5Ds | 7D MKII | 7D | G16 | G3x | EOS M & M3 | 800 f5.6 | 600 f4 | 400 f2.8 | 300 f2.8 | 200-400 f4 | 100-400 f4.5 - 5.6 II x 2 | 70-200 f2.8 | 14 f2.8 II | 50 f1.2 | 50 1.4 | 85 f1.2 | 135 f2 | 24-70 f2.8 II | 11-24 f4 | 35 f1.4 II | Pentax 645Z | SMC Pentax-DA 645 25mm F4 AL | SMC Pentax-D FA 645 55mm F2.8 AL | Pentax 90mm f/2.8 D FA 645 Macro ED AW SR | SMC Pentax-D FA 645 200mm f/4 IF | SMC Pentax-D FA 645 300mm f/4 ED IF | SMC FA 645 400mm f/5.6 ED IF Lens
gasrocks
May 21, 2009 10:45 |  #2
And LenAlign is ?
unnerv
May 21, 2009 11:41 |  #3
I don't have one gasrocks, but you can see what they are here: http://www.rawworkflow​.com/lensalign (external link)
BigBlueDodge
May 21, 2009 13:38 |  #4
Canon recommends 50x the focal length of the the lens being tested. When calibrating a zoom, you need to decide what focal length you are calibrating against. If you want to calibrate at the 10mm end, the LensAlign target needs to be 500mm away (or 19.58 inches). If you want to calibrate it at the 22mm end, then the target needs to be 1100mm (or 43.3 inches away).
Same thing appies to the 70-200.It's really easy to calculate
Distance In MM = (Focal Length * 50)
Distance In Inches = (Focal Length * 50) / 25.4
Do understand that calibration is really only guaranteed for the focal length tested. If it possible, via manufacturing tolerances, or lens design, that the calibration for the wide portion of the lens is not applicable to the tele portion of the lens.
David (aka BigBlueDodge)
Gear
number ­ six
"After 40 years still not housebroken, I still piddle on the carpet"
May 21, 2009 16:01 |  #5
Bear in mind that the recommended distances are from the sensor, not the front of the lens.
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
I do not piddle on the carpet!
joove
May 21, 2009 16:24 as a reply to  @ number six's post |  #6
If you need the numbers again, pick the longest focal length of the zoom and open to the widest aperture. The whole point is to get a DOF thin enough for you to be able to distinguish the OOF regions. Then enter into google search
(200mm * 50) in feet
and you'll get it in feet. I love google for unit translation. Use it for cups in tsps and such esoteric (for me) conversions.
Vamsi
Gear list
int2str
May 21, 2009 16:28 as a reply to  @ joove's post |  #7
This chart was posted on the lens align forum:
IMAGE: http://www.whibalhost.com/_ss/lensalign/lensalign_dof_distance.jpg
Note that Michael from lens align suggests that 25x focal length is fine as well.
3,249 views & 0 likes for this thread
Latest registered member is biffleg
1099 guests, 338 members online
