Thread started 22 May 2009 (Friday) 12:17
Sharp/Fast Wide Angle for a FF sensor
aram535
May 22, 2009 12:17 |  #1
Got an assignment that I would like some advise on. I'm putting in a Soccer Goal Camera, on a poll (2 ft behind the net). I was going to use a 85mm f/1.8 on 1Ds Mark II with a Bogen SuperClamp and PocketWizard.
I am finding that the 85mm just might be too long, something shorter would be preferred. Although I have an arm so that I can actually put the camera behind the poll as well. Also, there is some vignetting going on with the 85mm and FF sensor.
So options:
  1. 85mm f/1.8 on the arm and just pull it back further (poll being visible might be a problem, so will slippage using the arm)
  2. 24mm f/1.4L I or II
  3. 50mm f/1.4
  4. 16-35mm f/2.8
Any notes/suggestions?
P.S. I'm thinking f/11 @ 1/500th (faster if I know I'll get a couple of hours of good sun light). 50mm give me between 6-10ft of focus, and 24mm will give me between 3 ft to infinity, which is nice.
Gear List * www.tranquilphotos.com (external link) * My Blog (external link)
bohdank
May 22, 2009 12:23 |  #2
If you need to cover the whole net, (post to post) the 85 is going to be way to long, imo.
The way you are describing it, I think you'd be looking at something < 20mm on a FF.
16-35 should cover it nicely.
aram535
May 22, 2009 13:04 |  #3
Hmmm I do have a 14mm as well, its a bit of fishy output but it can be flattened in photoshop pretty well, maybe that's a better choice.
anorphirith
May 22, 2009 13:54 |  #4
how about the 17-40mm ? canon's most popular lens
tremendous results
1DsII 50mm f/1.4, 28-75mm f/2.8, 135mm f/2L
-Kiev 88, 120mm f/2.8 ! 80mm f/2.8
-Leica R3
-Canon AE-1 & Kodak retina I a
jerokaz
May 22, 2009 14:10 |  #5
What about the 24-70? You are using on a FF camera. Then you could get the shot perfect.
www.rmbphoto.net (external link)
Canon 1DMKII, 20D Gripped, 24-70 2.8L, 70-200 F2.8L, 400 5.6L, 1.4 TC MK2, 50 F1.8 MK2, 85 F1.8, 18-55 Kit, 580 EX MK1, 430 EX, 420 EX, ST-E2, CP-E3
bohdank
May 22, 2009 14:41 |  #6
aram535 wrote in post #7970102 (external link)
The 14 would be wide enough, probably too much so. I would go with the versatility of a zoom, since you would be less pressed if having to change the location of the lens.
The 17-40, mentioned would be a good, less expensive, alternative .
thomasro3
May 22, 2009 14:46 as a reply to  @ bohdank's post |  #7
I'd say the 16-35 or the 24-70 would be the best two options.
5DMIII, 20D, 16-35L II, 24-70L II, 24-105L, 70-200L II 2.8 IS[COLOR=black], 50L, 100macro, 15 fisheye, 1.4extender II, 2x extender III, 600EX x2, (CPS USA Member-the free one), Powershot D10 (WaterproofCamera).
Wishlist includes:, 85L, 200L love the NEW 400mm but at 11.5k Its a wet dream and some training/instruction to do the equipment justice.
Double ­ Negative
*sniffles*
May 22, 2009 17:20 |  #8
24L or the 16-35L, IMO. You can't shoot at f/1.4 anyway since the DoF will be too shallow. So f/2.8 would be a good minimum. The 50/85mm lenses will be too long that close to the net.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
xarqi
May 22, 2009 17:28 |  #9
The longest lens that will encompass the whole of the goal mouth (8' x 24') from 12' behind the line (10' net + 2' additional) is about 18 mm for FF. The required AoV is 90°.
The only one on your list that will do the job is the 16-35.
thomasro3
May 22, 2009 17:51 |  #10
xarqi wrote in post #7971401 (external link)
Well there you have it.... A definitive exact calculation. Impressive. Thanks
BTW. I love your Vent...we have a similar problem in the office with people confusing affect vs. effect. Oh and ensure vs insure.
aram535
May 22, 2009 18:02 |  #11
I don't think the Net is 10' deep, more lke 3' and the poll is only another 6"-10" back. That doesn't change your calculation a whole lot, but just to note it.
I don't know the DoV of the 14mm but it can't be much more than the 16mm, no? The only reason I'm thinking the 14mm is that I already have it, where as the 16mm or 17mm lenses I would have to rent. They're not much less than $100 for a 7 day rental.
xarqi
May 22, 2009 18:20 |  #12
aram535 wrote in post #7971554 (external link)
I looked into that. The standard size for a soccer net is usually given as 24 x 8 x 10 x 4, which, by my reckoning, puts part of it in hyperspace! It turns out though that it's 4' deep at the top, and 10' at the bottom.
It sounds like your situation may be different, but if you have exact figures, then an exact calculation can be done.
The first step is a bit of trigonometry. Given w, the width of the goal, and d, the distance of the camera behind it, the required horizontal angle of view is:
2 x arctan(w/2d)
(Unless the goal mouth is an odd shape, the vertical aspect should be OK).
Armed with that, head over to -->here<-- to pick up your handy AoV table (courtesy of 20droger) and see what fits.
P.S. I have assumed that the camera will be mounted halfway between the posts horizontally, and at half the height of the goal mouth vertically.
1,591 views & 0 likes for this thread, 7 members have posted to it.
1588 guests, 137 members online
