Thread started 22 May 2009 (Friday) 16:08
Thinkin about a used 1D mark 2
Dooms_day
May 22, 2009 16:08 |  #1
i think im definately going for a 1d, but the problem is which one, either a 1D mkII or mkIIn, i havent really seen a topic on the diferences, and its kinda hard to search on the forums 'mkII vs mkIIn', anyway, tell me some quick facts about either or....;)
Canon EOS-1D mk ii + 70-200 4.0 USM L + Sigma 28-70mm 2.8-4 + Nifty 50
500px (external link) - Google+ (external link)
hardcorewaterfowl
May 22, 2009 16:37 |  #2
I made the move from a 40D last month to a 1DmkII. Best thing I could have done. I've been shooting sports and was a little disappointed in the 40D. A learning curve on the controls and what the body can do, but well worth it. If your coming from an XSi you will be amazed at the weight difference, better balance with a big lens though.
Jman13
May 22, 2009 16:54 |  #3
There have been a few firmware tweaks between the IIn and the II...the biggest change is the larger LCD, picture styles, and a more efficient buffer for a few more shots in a burst. Other than that, they are the same. Same sensor, same processor, same AF, same sealing, etc.
Jordan Steele - http://www.jsteelephot​os.com (external link) | https://www.admiringli​ght.com (external link)
Canon EOS R5 | R6 | TTArtisan 11mm Fisheye | Sigma 14-24mm f/2.8 | RF 24-105mm f/4L IS | Tamron 35mm f/1.4 | RF 35mm f/1.8 | RF 50mm f/1.8 | RF 85mm f/2 | RF 70-200mm f/2.8L IS | Sigma 135mm f/1.8
cdifoto
Don't get pissy with me
May 22, 2009 16:56 |  #4
Dooms_day wrote in post #7971034 (external link)
You don't see many topics on the differences because there aren't many, and none of them are integral to great images. It's like the 20D vs the 30D.
k_wakasugi
May 22, 2009 17:01 |  #5
Larger buffer, larger screen, picture styles, automatically creates new folders when file numbers reach 9999, and the ability to write RAW to CF and JPEG to SD and vice versa, and uh... I think that's pretty much the jist of it.
FS: 85 1.8 w/hood - $300!!!
1D Mark II - This is my Canon. There are many others like it, but this one is mine.
k_wakasugi
May 22, 2009 17:03 |  #6
Oh, and about $500-600 used. That sums up the differences.
Results of a 4 second google search. That wasn't too difficult.
http://photo.net/equip​ment/canon/1dIIn (external link)
=P
jgtuk
May 23, 2009 02:59 |  #7
k_wakasugi wrote in post #7971282 (external link)
=P
404 - Page Not Found
zincozinco
-Followers of Fidget-
May 23, 2009 03:46 |  #8
Honestly i see no reason for one over the other, get the one which is best in price, and least shutter count. These beasts normally see a lot of action.
Living the life, overexposing...
Web (external link), Blog (external link) Name: Mike, Maik, Micke or just zinco.
george ­ m ­ w
May 23, 2009 06:56 |  #9
I just bought a used 1D2. Buy it...you'll love it !
Look over on the dp review site for details. Here's the link for the "1D2n", and if you look down through the list of non current models, you can read the whole test of the 1D2
http://www.dpreview.co​m …082208canoneos1​dmkiin.asp (external link)
regards, george w
"It's also obvious that people determined to solve user error with more expensive equipment will graduate to expensive user error."
Dave N.
joe9047
May 23, 2009 07:25 |  #10
george m w wrote in post #7973901 (external link)
I was thinking of going this route. What would be considered a decent shutter count for this camera?
Joe
Gear
george ­ m ­ w
May 23, 2009 07:39 |  #11
I'm not sure there is a really definitive answer to that. A good starting guideline would be that they are 'duty rated' at 200,000. Of course that does not mean it will fail at that point....nor does it mean it will last that long. Some fail early....some actually just keep on going. The body I just bought was an "ugly" one from KEH...thread here about it:
https://photography-on-the.net/forum/showthre​ad.php?t=693992
.....mine has 130K on it....but I got it cheap enough that if I have to have the shutter replaced, I won't feel to bad about it. As always, buying used is a bit of a pig in the poke.
regards, george w
Dave N.
joe9047
May 23, 2009 07:48 |  #12
george m w wrote in post #7974003 (external link)
Thanks George. Much appreciated.
Joe
Gear
n1as
May 23, 2009 08:08 |  #13
I too went from 40D to 1D for sports and I wanted the IIn but then realized I could keep my Tokina 11-16 to go with my XSi if I got the cheaper Mark II instead. Boy am I glad. The Tokina 11-16 is a fabulous UWA on the 1D!
Comparing the 40D to the 1D II here's what I see.
- AF is much, much better.
- Viewfinder is nicer (sharper, bigger)
- Weight is significantly higher
- No more bolt-on grip that is never tight
- Using the LCD to review images is almost useless
- Flash exposure is off by about 1 stop by FEC corrects it just fine.
- IQ went up
- High ISO noise is about the same
About the LCD - The 1D II has such a small / poor display that it is pretty much useless for confirming focus or stop action. I can use it to review the histogram but only if I'm not outside in bright light (overcast or brighter). So, I've quit looking at the LCD and I just shoot.
Actually, the bulk of the user interface is not as nice as the 40D. You always have to hold one button while pressing another to make the camera do anything. This means changing ISO or WB, viewing images or histograms, etc. takes 2 hands. Hassle. But it also means you won't accidently change mode, ISO, WB etc.
IQ is higher with the 1D too. Colors are a bit richer, things are a bit smoother, all my lenses are a bit sharper.
Battery life is somewhere around 1000 frames - very nice!
My 1D has 70K clicks and I paid about $1100 for it. It has some minor exterior "battle scars" that I didn't even notice for the first month. I'd love to upgrade to the IIn but there are better things I could do with the $500 it would cost.
- Keith
http://darwinphoto.zen​folio.com (external link)
Headshotzx
May 23, 2009 08:55 as a reply to  @ n1as's post |  #14
Hm, I'll just slot my question in here. So what if you're comparing the 50D (which is essentially a 40D with a better screen and more mp) versus the 1D mark IIn (which is a 1D2 with better screen and buffer)?
Zexun | Flickr (external link) | YouTube (external link) |
Mr. ­ Clean
May 23, 2009 09:01 |  #15
I've said it a few times, the Mark II is, in my opinion, the best bang for the buck camera out there. 1000 bucks usually for 1 series performance? You'd be crazy not to.
I do like the 40D's color, and the 40d dpes take great pictures but I love 1 series cameras and their reliability is second to none.
Mike
some shots @ Zenfolio (external link)
2,703 views & 0 likes for this thread, 17 members have posted to it.
Latest registered member is sinonaut
719 guests, 118 members online
