Thread started 22 May 2009 (Friday) 22:46
Sharpening action
boog69
Joined Nov 2005
May 22, 2009 22:46 |  #1
I've created an action to sharpen. It runs fine and saves to the output folder. Only problem is it starts with pic 1 and then jumps to 10 and then to 100. It runs from 100 all the way through the rest. Any ideas why? I didn't record that way. Thanks.
Canon 40D, Canon 20D, Panasonic FZ-30, Canon 17-40L, Canon 70-300 IS, Canon 85 1.8, Canon 50 1.8 MK I, Canon 550 EX flash. Wishing for 135L:D !!!
poloman
May 22, 2009 23:34 |  #2
Just write the action to work on one file and run it from within file/scripts/image processing. Then you can use the action on just one file or a thousand.
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
tim
Light Bringer
May 22, 2009 23:55 |  #3
Are you talking about the order that it runs on files? If so then it's irrelevant. It happens because of the way the filename sorting's done - alphabetic vs numeric.
tonylong
...winded
Gallery: 60 photos
May 23, 2009 00:26 |  #4
tim wrote in post #7973010 (external link)
Good catch, Tim! That drives me nuts sometime -- to run a process or download to a Web site and then find that my number extensions are all messed up from that!
I wonder if that's the OPs problem?
Tony
boog69
Joined Nov 2005
May 23, 2009 01:01 as a reply to  @ tonylong's post |  #5
Thanks for the replys. Tim, I didn't know that but all my files are named FD2009-1, FD2009-2 all the way to FD2009-240 so alphabetic shouldn't make a difference. Am I missing your point? Thanks again for help. Is there anyway to keep this from happening as the picture are to be in a certain sequence? Plus I still don't really understand why it goes from 1 to 10 to 100 and goes from 100 and stayed in order before I stopped at about 115. File size have anything to do with it?
tim
Light Bringer
May 23, 2009 01:40 |  #6
You need to describe your problem more clearly, I don't know what the issue is.
boog69
Joined Nov 2005
May 23, 2009 09:01 as a reply to  @ tim's post |  #7
When I picked my source file to run my action, why does it not go in numerical order? My files are all named the same thing except at the end where the number goes 1,2,3,4,5..... I wouldn't think alphabetical order would be an issue. When I ran the action, it went from file 1 to file 10 and then to file 100 skipping all in between. After it hits 100, it seems to stay in numerical order but I've never let it finish. I stopped it around file 120 and it had stayed in order. I hope this is a little more clear.
thaking
May 23, 2009 09:25 |  #8
lemme take a stab...your files end with a number (1,2,3,4,5...10,11,12.​..101,102,103), correct? if this is the case ALL images that begin with a 1 will go first - 1, 10, 100, 101, 102, 103, etc...AFTER all the images that begin with 1 have been processed it would go to 2...so 2, 20, 200, 201, 202, etc...
if your images were numbered with 3-digit codes, they would be numeric...001, 002, 003, etc...
Roy ­ Mathers
I am Spartacus!
May 23, 2009 09:43 |  #9
I think you've got it there thaking - that's almost certainly the cause of the OP's problem. It's always safer to save the files with three-digit codes.
poloman
May 23, 2009 11:48 |  #10
Put all the files in one folder and use the suggestion I offered earlier....
tim
Light Bringer
May 23, 2009 17:34 |  #11
I already told you the answer, and thaking expanded on it. Really what are obsessing about? The point of a batch job is photos are all processed the same way, the order doesn't matter. Since the output will have the same name as the input if you're written your action correctly this is irrelevant.
For the pedants, name your files xyz0001 not xyz1
thaking
May 23, 2009 18:05 |  #12
and if you think you're going to have 10's of thousands of images, use 5 numbers (xyz00001)...sorry tim, just wanted to expand again. ;)
boog69
Joined Nov 2005
May 23, 2009 18:10 as a reply to  @ tim's post |  #13
Tim, Tony, I always appreciate your help. Thaking, you made the light bulb come on. I don't use actions very much and I just assumed it went 1- whatever. Poloman, I'll have to check more into what you mentioned. Thanks for all the help.
tonylong
...winded
Gallery: 60 photos
May 23, 2009 18:19 |  #14
Boog, take a test batch numbering from 1-20 and run it. If we are correct, you will see the sequence processing like this:
1,10,11,12,13,14,15...​2,20,3,4,5,6...9
Tony
thaking
May 23, 2009 18:19 |  #15
no problem...i remembered this because as a software designer we were working on a project...we labeled some files 1-whatever and then did some stuff to these files...well, we were baffled at first because it was taking them out of order...then we realized we needed to number them 001, 002 and so on...
so it's not always so obvious at first, but once someone mentions it you're like "oh yeah, that makes sense."
good luck!
1,937 views & 0 likes for this thread
Sharpening action
Latest registered member is Ashawii
909 guests, 235 members online
