blueskyyy wrote in post #7975510
I just did some searches as well, and I came across many good stuff. I live in central valley, California. I want to go out and buy an air compressor and blow the dust away, but I am kind of scared to try that. On the other hand, it's the weekend and it's going to be a couple of days before I could get any cleaning supplies ordered out to me. I might just wait.
But would you guys think using the air compressor is a bad idea? If so, then I will wait it out.
Thanks.
I don't know for sure what you mean by "air compressor", but if you mean compressed air, as in canned, don't do it on the sensor. It's too easy to blow contaminants and even debris onto the sensor. Use a bulb-type blower to see if you can remove some of it. I'm guessing it won't do the job, but always worth a try in the beginning.
It's pretty frustrating for me to keep mine clean, but I finally got it last week. Now, at F38 (highest I've been able to achieve), I can just make out one very weak speck . It should now be fine for normal use. It took me many tries to get the job done. In four sessions several weeks apart, I have found that only wet cleaning works for my sensor junque. The dry brush, even Arctic Butterfly, just moved the stuff around. Only "mopping it up" with the wet system worked for me. I'm very careful when changing lenses, but we live in a very "dirty" environment here.
