Thread started 23 May 2009 (Saturday) 23:58
View finder has specs
hammmerhead
May 23, 2009 23:58 |  #1
Is there any way to clean your inner viewfinder? I have some specs that I can't get rid of from really dusty conditions. It seems like they can't be removed from the lower lens or they are inbetween the layers. My sensor is spotless and the textured lower part of the view finder cant seem to come clean Thanks friends.
MAX2
50D | 10-22 | 24-105L | 70-300 IS |SIGMA 30MM 1.4
AlanU
Gallery: 144 photos
May 24, 2009 00:47 |  #2
If your lucky your focus screen is dusty, dust can also reside between the focus screen and the screen with the 9 points/circle or ........its in the pentaprism area.
After you unclip the focus screen you'll have access to the SI plate. To remove the plate you unscrew 2 philips screws. The SI plate is on top and the below it is the retaining bracket (clip for focus screen access door and 2 tabs that retain the shim that holds the "screen with 9 points and circle".There are shims between the focus screen and other screen.
After all that is removed your in the area where dust has accumulated. I used a rocket blower and its was useless. I took apart the camera again and used "dust off" keeping the can upright. Blew that area and every spec of dust in the viewfinder was gone.
I could have had it done by canon under warranty but I do not trust Canada's Mississauga's Canon Sun camera "authorized" monkeys.
I dont recommend doing it yourself. If you send it to Canon they will do the same as I did.
5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
Fuji - gone
Sony 2 x A7iii w/ Sigma MC-11 adapter | GM16-35 f/2.8 | Sigma 24-70 ART | GM70-200 f/2.8 |Sigma Art 24 f/1.4 | Sigma ART 35 f/1.2 | FE85 f/1.8 | Sigma ART 105 f/1.4 | Godox V860iiS & V1S
ron ­ chappel
Honorary Moderator
Joined Sep 2003
May 24, 2009 05:32 |  #3
Its not difficult if you can handle small parts.Even if you mix the parts up (the viewfinder focus won't match the AF) its not hard to rearrange them 'till its right.
Just one word of warning -don't be tempted to use any cleaning fluid on the screen as this will almost certainly leave permanent swirl marks!
captainkimo
May 24, 2009 06:21 |  #4
If it doesn't affect your photos, maybe just leave it as it is. But if it really distracts you, I think it might be better to send it to Canon service center than you DIY. Just my two cents.
Cheers!
Captain Kimo
HDR Photography by Captain Kimo
www.CaptainKimo.com (external link)
Reach the Captain on FaceBook (external link)
tvphotog
May 24, 2009 10:05 |  #5
I don't know where you are, but Canon service in New Jersey is superb. Don't know what the UPS charges would be, but it's better than screwing up your camera and then having to send it in.
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
chinoamigo
May 24, 2009 10:26 |  #6
did you try using a blower? that happened to me before, but i just used my air blower on the inside of the camera and it was fine after.
go full frame!
hammmerhead
May 24, 2009 17:32 as a reply to  @ chinoamigo's post |  #7
Well I took it apart and was pretty shocked on how easy it was to service. One thing that was tough was getting everything lint free when I put it back together. I used a can of dust free to blow everything off after it was cleaned. Its a lot better than it was, but I still have few specs. This really makes you appreciate having a perfectly clean view. I removed the focus screen and the, I think it called the SI plate? ...the one with the focus dots. Anyway there is another element above that I would like to clean. It seems q-tips do more harm than good with leaving fuzz behind. Anyone use any solution or cleaning tool to handle this? Man, cleaning the sensor is a joke compared to trying to get the viewfinder 100%
MAX2
1,969 views & 0 likes for this thread, 6 members have posted to it.
1689 guests, 181 members online
